Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
What should I do next?
Old 05-20-2007, 08:40 PM
phorr20
phorr20's Avatar
Default What should I do next?
I posted in the 4.6 sec. but here it is again.
I don't know what to do?
#1 PI Swap then Supercharger (Could take awhile)
#2Cams & Supercharger (Would I need to do anything else to the motor? Can I do the cams first then s/c later?) What cams & s/c would you guys suggest?
#3 PI Swap only
#4Superchargers only
Leaning more towards #2.....what cams & S/C would you guys suggest?
I'm really looking for low end power....off the line power. Is there another set-up for this?
Thanks for any help you can provide.
I took some pics when I was out last night...check them out
http://i148.photobucket.com/albums/s36/phorr20/Silver%20Stang/SinCityMustangs047.jpg
http://i148.photobucket.com/albums/s36/phorr20/Silver%20Stang/SinCityMustangs001-1.jpg
http://i148.photobucket.com/albums/s36/phorr20/Silver%20Stang/SinCityMustangs077.jpg
phorr20 is offline
Old 06-06-2007, 01:30 AM
ruffrider4403
ruffrider4403's Avatar
Default RE: What should I do next?
s/c kit is gonna give you the most bang for ur buck. if you plan on building a motor to handle more boost, then eventually get a new heads, etc...... but that would be ur best bet for now to run 4-500hp
ruffrider4403 is offline
Old 06-06-2007, 02:54 AM
jst854
jst854's Avatar
I would go pi swap then fi. However I would only suggest the pi intake and then a set of cams and while you are doing cams you mines as well put in aftermarket cams right away. I swapped the intake and the enigine pulls all the way to red line. I highly suggest it.
jst854 is offline
Old 06-06-2007, 10:30 PM
pigmie
pigmie's Avatar
what are the best aftermarket cams for the 4.6 L
pigmie is offline
Old 06-07-2007, 01:23 AM
dutman98
dutman98's Avatar
There is a guy that has a blown 97GT. He did his supercharger before his intake swap and made pretty good numbers then did the Pi intake and made alot more power. I would suggest that you do the intake and maybe cams too. If you do the heads you have to run low boost.
dutman98 is offline
Old 06-07-2007, 02:20 AM
86 GT 5.0
86 GT 5.0's Avatar
ORIGINAL: dutman98
Who says you have to run low boost???
86 GT 5.0 is offline
Old 06-07-2007, 03:12 AM
mnile9127
mnile9127's Avatar
ORIGINAL: 86 GT 5.0
ORIGINAL: dutman98
I'm sure that PI swap will raise his C/R , and it all depends on what you consider low boost.
mnile9127 is offline
Old 06-07-2007, 03:27 AM
dutman98
dutman98's Avatar
I have heard 8 to 10 and a good tuner you would be fine.The head swapups are compresstion on npi cars.
dutman98 is offline
