Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
vortech S Trim Question?
Old 10-08-2008, 08:29 AM
91stangy
91stangy's Avatar
Default vortech S Trim Question?
Last night i was told my blower is way to loud and the reason he thought is that there is a filter in the actual blower right after the feed line. Is this true? If so where do i buy a new one and whats the fastest way to change it?
91stangy is offline
Old 10-08-2008, 01:11 PM
Fobra
Banned
Fobra's Avatar
uhhh... what? S trims are loud if they are not SQ...
Fobra is offline
Old 10-08-2008, 01:12 PM
91stangy
91stangy's Avatar
i know this but he said his friend has one and its not as loud, he said there is a filter on the feed line which could be a little clogged this is why i asked?
91stangy is offline
Old 10-08-2008, 10:09 PM
89GTRagtop
89GTRagtop's Avatar
According to Vortech you should clean the oil inlet fitting every 3000 miles. When the engine is cold, remove the oil inlet fitting at the supercharger and blow it out with an air gun.
Make sure that you dont remove the screen/filter inside the oil feed housing.
89GTRagtop is offline
Old 10-09-2008, 10:43 AM
91stangy
91stangy's Avatar
so it is right behind the oil feed line?
91stangy is offline
Old 10-09-2008, 12:08 PM
5.0kid
5.0kid's Avatar
this is what mine sounds like from 20 ft back
5.0kid is offline
Old 10-09-2008, 03:58 PM
91stangy
91stangy's Avatar
Unhappy
yea that sounds about right, my exhaust isnt as throaty though
91stangy is offline
Old 10-09-2008, 04:00 PM
91stangy
91stangy's Avatar
still no answer on whether or not there is a filter on the feed line
91stangy is offline
Old 10-09-2008, 09:06 PM
FoxGT
FoxGT's Avatar
Gear driven superchargers are always noisy. If you're talking about the noise at idle, it is caused by the impeller. You can quiet it down alot by making the intake plumbing longer between the filter & supercharger. The shorter the plumbing from filter to compressor the louder it will be.
FoxGT is offline
Old 10-09-2008, 09:31 PM
89GTRagtop
89GTRagtop's Avatar
YES it is behind the fitting between the feed line and the supercharger, and there is a screen that acts as a filter inside the housing.
Quick Reply: vortech S Trim Question?
