chip questions, for supercharger
I got a vortech supercharger, but not sure if I need a chip or can a shop flash my ecu when I get my car dynoed?what my best bet if I have to get a chip?I have a 2002 gt. I'll be running a 8lb pully, 42 lb injectors, with a 90mm lighting maf.
RE: chip questions, for supercharger
You'll want to find a dyno shop that can do a dyno tune for you. This is the safest way to go. You can get a chip, but mail order chips really aren't that good.
I see you are in San Diego, check out JBA, they can do it for you. It will cost some $$$ (like $500) but it will help ensure your car will stay safe.
if the shop is a predator dealer they can use that with the dyno and get the custom tune you need. The predator has all the adjustable features you need to tune it correctly or atleast that is what they use at delk performance if you have the pred, would save me about 175 dollars on the tune
I'm not sure how JBA does it, I haven't really looked into it. You other option is the Dyno shop (I'm pretty sure they offer SCT) or you can check out someone in the LA area.
I totally agree that JBA is overpriced, but its worth it if it saves your engine.
I was considering the dyno shop, they said it $80 buck for a dyno. FYI any one readding this that liver in so cal there is a dyno day comming up (july 23) at the dyno shop i think it's $40 for 2 back to back pulls.
Luke9222
10-22-2015 11:55 PM
09-03-2015 07:14 PM
