eibach sway bars in, clunking sound?
So i put my sway bars in, finally, yesterday. noticed under certain conditions i get a clunking sound now. this occurs mainly under high compression and at an angle at a slow speed. for instance, coming into and out of steep driveways onto the road. going over speed bumps slowly at an angle.
the rest of my suspension is stock. was wondering if anyone has had this occur as well and if it is normal and if i'd be ok autocrossing. messing around in the car otherwise and i haven't heard a sound from them and they're performing very well.
i should mention that it is coming from the rear
hmmm. i'd say they're tighter than the factory sways. it didn't take much to break loose the stock bolts. i'll take a look though
Did you reuse any Ford bolts during the installation. These are one-time use only and may not hold the proper torque. I got some clunking from the front with my FRPP front swaybar install (similar bar to the Eibachs) and had to go back to the dealer to retighten everything. Check the torque settings again. Might also liberally grease the bushings as well.
Cheers.
Cheers.
all new rear bolts. front hardware was reused, but the sound is coming from the rear. perhaps not enough grease? but when i checked this morning there was def grease coming out from the bushings and the sway bar moved easily before i bolted everything down securely
i also found these torque specs online:
Front Stabilizer Bar Bracket Nuts: 70 Nm - 52 ft/lbs. (i assume these are the body mounts)
Rear Stabilzer Bar Bracket Nuts: 70 Nm - 52 ft/lbs. (body?)
Rear Stabilizer Bar Link bolts: 115 Nm - 85 ft/lbs. (at the wheel?)
so... i got the rear sway to stop clunking. i loaded up the 4 bushings with castrol full synthetic grease and tightened the bolts with a torque wrench. i got the body mount bolts to about 50lbs and the wheel mounts to 60lbs.
despite the specs found above i stopped at 60lbs because the outer bushing mount started to bend into the stock clip holes... i figured 85lbs would have broken something.
so now they're quiet, but its pouring out so i can't really get on it in turns.
