Need a lil help tightening up suspension
#21
Yep I do! I've done a bunch of changes to the suspension, some things twice, and have ended up with what I think to be the best combination of parts for "me". (Steeda Sport springs, Koni yellows, Fays2 Watts Link and Strano front/rear adjustable sway bars) That certainly might not be the best for someone else, but it works for me! Putting in the watts link was a night and day difference in the overall way the car rides and handles. With the equipment list on your car it should be a very noticeable improvement. I'd recommend finding someone who has installed them before and can help you tune it after the install. Sam Strano was a huge help with parts and advice.
#22
I have the full length BMR weld in subframe connectors. Most everyone says they are overkill, but I did them any way. Added weight vs Added rigidity
What A arm supports are you talking about?
Can you clear up my confusion on your front air dam/splitter???
#23
Below is the air dam splitter i have mine is just painted to match and i had the lip painted as well.... i dont recommend it to anyone that uses the car as a DD hangs WAYYY too low
http://www.steeda.com/products/steed...itter_s197.php
the A arm brace i was talking about are BMR A arm supports
#25
Same splitter that I have but yours is Carbon Fiber. I have ABS. Didn't have the carbon fiber in stock or available when I got mine.
#26
Ah! Must be the paint scheme that's throwing off my eye!
A arm brace/K member brace came stock on the '07's and newer. Check to see if you have one first. If not any brand will do. I have the Steeda. I also have the Steeda front sway bar braces. http://www.steeda.com/products/front...ount_brace.php
#27
#29
BTW how are the 4.30's treating u on that and im curious what that is running in the 1/4 like that
