Koni Yellow Adjustments
So I figured out what was going on. The strut and shock piston was turning instead of the actual adjustment ****. I had to hold the piston and the adjustment **** only turned 2 times in either direction. Problem solved and cool points gone.
I run mine fairly soft compared to what most people are saying. Possibly due to springs, tires, driving style, surface, etc. When at the track I start at one full turn up from full soft in the front and 1/2 turn in the rear. This usually gets me in the ball park of where I want to be but sometimes requires some playing around based on conditions. Otherwise, I just play with tire pressures. I run Eibach Pro-Kit springs and street tires, 275/40-18s all around. I am fixing to to sway bars so I'll probably play with adjustments more once that happens. I like it sprung fairly soft because most of tracks around here aren't the smoothest, neither are the streets. On the street, I run pretty much 1/2 turn in the front and full soft in the rear.
A lot may depend on the track, which could explain the differences. I've found that at Buttonwillow, if I go with much more damping on the rear, the back end will start skipping a little on certain sections with high speed turns.
On the street, I run softest in the rear and 1-1/4 up front.
I heard from some guys in Europe that the Koni yellows should be 'broke in' by running on full soft for a while.
My first mod to my new GT will be the Koni's. I have put them in our DD Volvo V70 plus other Volvos and BMWs. Definitely worth the extra $$ over Bilstein HD's.
The guys in Europe must be smoking something. No need to "break them in". Not sure what exactly they think they are getting done by doing that. I never run them full soft (well can only think of one time I did on the rear of one car) and I've never had issues and I've owned at least 5 sets myself.
And there is the common thread amongst all of us who have had both.... Koni's are more composed, they just do the job better.
Just a reminder that I have PLENTY of Koni's in stock.
I will put in an order with you in about a month.
