HELP WIT BETTER SUSPENSION
Old 01-25-2012, 12:11 PM
ralphmustang
ralphmustang's Avatar
Default HELP WIT BETTER SUSPENSION
HI,
I Notich when driving on high speed (have Vortec Ho) that the car have not great balans...and is not steady enough..... i have already adustable panhard ,swaybars, roush shock bilstein springs......what can i do to get my car more relax on high speed i feel that the car is not the same as an audi or bmw at high speed ..how can i improve that??
ralphmustang is offline
Old 01-25-2012, 12:20 PM
Menace
Menace's Avatar
This thread will probably be moved to the appropriate section, but with all of those modifications it's hard to understand exactly what you are asking. Is your ride too stiff or is the highspeeds pushing you around? These cars aren't the most aerodynamic so if that's the case you might look into modifications to increase that... perhaps you are in need of an alignment? You probably aren't going to get a luxary car "feel" out of this car. If anything your modifications probably only made your ride stiffer.
Menace is offline
Old 01-25-2012, 12:53 PM
MustangFirstCar
MustangFirstCar's Avatar
Can you better describe what you are feeling and at what speeds? With your mods I would suspect that your ride is a little harsh over highway pavement at high speeds, and unfortunately there is nothing you can do if that be the case. Great handling struts/shocks/springs are just rough, besides having adjustable ones and making them soft, there is not much you can do.
MustangFirstCar is offline
Old 01-25-2012, 01:00 PM
Roy_R
Roy_R's Avatar
Bet the compression/damping of that shock/spring combination is not complementing each other, hence the loose feel of the car.
This guy races Stangs, ask him for advice (Sam)
http://www.stranoparts.com/
Roy_R is offline
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: HELP WIT BETTER SUSPENSION
