Best and cheapest way to improve launch?
Old 04-27-2012, 12:59 PM
Swaggertooth
Swaggertooth's Avatar
Default Best and cheapest way to improve launch?
Does anyone recommend simple and cheap ways to improve my launches? I was thinking about control arms? coil over kits are sort of expensive..
Swaggertooth is offline
Old 04-27-2012, 02:24 PM
Andy13186
Andy13186's Avatar
better tires 100%, preferably drag radials
lighter and wider rims with wider stickier rubber would be best.
i got pilot super sports 295 30 20's and the difference between them and stock is amazing, powershifting to 2nd at full throttle doesnt even hardly break the tires loose
Andy13186 is offline
Old 04-29-2012, 03:08 PM
808muscle
808muscle's Avatar
Racing tires are the single best mod for the track. If you have wheel hop, then LCA's will eliminate that. Manual or auto trans?
808muscle is offline
Old 04-29-2012, 04:41 PM
jsimmonstx
jsimmonstx's Avatar
The best way is almost never the cheapest way to do anything.
jsimmonstx is offline
Old 04-30-2012, 10:02 AM
outceltj
outceltj's Avatar
What 808 said and that will not be cheap but ur best option
outceltj is offline
Old 04-30-2012, 09:23 PM
parchisi
parchisi's Avatar
What everyone else said. Drag radials, or slicks if you want to schlepp them to/from the track. Aftermarket control arms with stiffer bushings (or rod ends if you're really hardcore) should reduce/elimiate wheel hop if you're having that problem. Some drag shocks/struts will absorb some shock and help the launch and weight transfer as well. Then there's of course adjustable 3rd links so you can play with pinion angle. Weight loss (both the car and driver if applicable) and driver skill will help as well.
If you're putting down higher power levels with sticky tires, there's also a good chance your clutch will become the weakest link and start to slip (like my friend's 05 with a KB and BFGoodrich KDW's)
parchisi is offline
Old 05-02-2012, 10:53 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Probably in this order:
Sticky tires
Control arms- http://www.uprproducts.com/mustang-c...ackage-05.html
Drag Springs- http://www.uprproducts.com/mustang-e...ng-kit-05.html
Shocks- http://www.uprproducts.com/mustang-q...-shock-05.html
Swaybar delete- http://www.uprproducts.com/mustang-s...inator-05.html
is the car an automatic or manual?
UPRSharad is offline
Old 05-04-2012, 11:40 AM
SteedaBrandon
Former Sponsor
SteedaBrandon's Avatar
I would recommend our drag pak stage 1 kit: http://www.steeda.com/store/steeda-d...d-mustang.html
Our parts are made in the USA and feature a lifetime limited warranty. Our lower control arms will help you get rid of any wheel hop and improve your launches.
Please let me know if I can help you with that!
SteedaBrandon is offline
flash_xx
10-16-2015 07:23 AM
TCStangerv6
10-11-2015 05:57 PM
UrS4
09-30-2015 10:13 AM
Daddys Girls GTs
09-14-2015 08:46 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Best and cheapest way to improve launch?
