Eibach Sway Bar kit FYI
Old 05-19-2012, 12:53 AM
2008Vert
2008Vert's Avatar
Default Eibach Sway Bar kit FYI
Installed a front/rear Eibach sway bar kit on my 08 V6 Convertible about a week ago.
Install was fairly easy but just remember to have weight on the suspension before tightening the bolts. The convertible was a little fidgety getting the rear bar above the extra bracing. I had to remove the rear wheels, then fish the bar into place, reinstall the rear wheels and get them back on the ground before installing the bar.
The front is pretty straightforward but remember that the bolts used from the factory are one-time use bolts. It's up to you but I got all new ones.
The end link bolts can be aggravating as it's much easier to tighten them with the wheels off, but you can't do that because you need to have the weight on the suspension.
Torque the end link bolts in the rear to 85 ft/lbs and the mounting bolts to 52 ft/lbs. Opposite for the front. Mounting bolts 85 and end link 52.
After driving for a few miles I developed a popping noise in the back. I double checked the torque and found the end-link bolts had loosened. Re-torqued and everything is great.
The ride is great, the handling is great and it should have been done this way from the factory. Well worth the money. I got all my stuff from Late Model Restoration (LMR) for 339 for the bars and 59 for a single bar strut brace.
This is just my experience and FYI for anyone installing these bars.
2008Vert is offline
Old 05-21-2012, 09:52 AM
tr3flip
tr3flip's Avatar
Good stuff! Did you get the adjustable or non-adjustable rear bar?
tr3flip is offline
Old 05-21-2012, 06:38 PM
2008Vert
2008Vert's Avatar
I got the adjustable 35mm front bar and non adjustable 22m rear. I set the front in the "center" hole which is supposed to be the most neutral (understeer/oversteer) position.
2008Vert is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
Quick Reply: Eibach Sway Bar kit FYI
