Upgrade GT Coyote to spank Camaro SS-1LE
Old 11-22-2013, 07:19 AM
  #81
jRaskell
jRaskell's Avatar
Originally Posted by Black Fire
Also the Boss Suspension is not much different then the Brembo/TP. Slightly stiffer springs 5 way adjustable shocks and a 1mm larger rear swaybar. In fact Terry Fair from Vorshlag states the cars are less then 1 second apart in road coarse times.
Shocks alone can make a night and day difference in the way a car handles. I can't attest directly to the differences between the Boss and Track Pack shocks, but for example replace nothing but the Base GT shocks with Koni Yellows, and it literally becomes a completely different car to drive. I say that with first hand experience.
jRaskell is offline
Old 11-22-2013, 08:18 AM
  #82
Steve@Tasca
Former Sponsor
Steve@Tasca's Avatar
The brake info is incorrect for the Mustang, Brembo/Track Pack cars have 14 " front rotors and Brembo calipers.
I knew that actually, not sure why I didn't catch it.
Still the Camaro has an advantage in rear brake size and with the larger contact patches is able to make better use of those brakes.
I've said it before, I can't wait to see what we get with the next generation Mustang. Hopefully Ford will learn something from all of this.
Steve@Tasca is offline
Old 11-22-2013, 02:10 PM
  #83
Black Fire
Black Fire's Avatar
I agree a quality set of performance shocks can do wonders even on a stock setup. I think that Ford should have done a Watt's Link set up on the Boss also because it would have made the package even better.
Black Fire is offline
Old 11-22-2013, 03:30 PM
  #84
Norm Peterson
Norm Peterson's Avatar
The Camaro has a slightly stronger argument for larger rear rotors, given that it starts out with a slightly greater percentage of its static weight being carried back there. Additionally, the Camaro's longer wheelbase directly reduces the amount of load transferred forward under braking, and the Camaro's CG height may well be the same or even lower than the Mustang's (pushrod engine CGs tend to be lower than the CGs for OHC engines, and the listed overall height is lower).
Those differences are not enough to justify 14.4" rotors vs 11.8", so you'd have to look at master cylinder and rear caliper piston diameters, where I'd expect to find the Camaro's to be slightly different from the Mustang's (either a larger rear M/C bore, smaller rear wheel cylinders, or both).
Norm
Norm Peterson is offline
PaulH2
20
01-31-2016 09:48 AM
Matt's 95 Stang
10-05-2015 07:16 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Upgrade GT Coyote to spank Camaro SS-1LE
