S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
Rear end problems?
Old 08-02-2013, 11:22 AM
wcgman
wcgman's Avatar
Default Rear end problems?
Just took my 07 GT500 in for an oil change and they were saying the fluid in the rear end is low. The tech pulled the plug and said there was metal shavings and I couldnt tell for sure, but I would say there could have been metal specs.
Car has 8900 miles on it and of those a small amount are of course hard driving but no nearly all of it. He said that he could feel fluid in the rear end and I thought that was fine since that fill plug is tiny if you can feel fluid...it's gotta be fine.
What do you guys think? Break in explain the shavings and being able to feel fluid is fine? Car is under warranty so Im not worried but if ya'll tell me to be then I will.
wcgman is offline
Old 08-02-2013, 08:19 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Was this at the Ford dealership? Over on AFM, there is a thread like this, and Deysha from Ford Corporate said something about a recall or TSB on this. She said a Ford dealer can run your VIN and tell you if this applies to you.
UPRSharad is offline
Old 08-03-2013, 02:58 PM
6-Speed
6-Speed's Avatar
According to the Mustang shop manual, the 8.8" differential requires 3.17 pints of fluid and the level should be 1" to 1.125" below the bottom of the fill hole. This assumes you have the OEM differential cover.
6-Speed is offline
Old 08-03-2013, 06:20 PM
wcgman
wcgman's Avatar
Thank you Sharad and 6S. I do have the OEM cover and that sounds consistent with what the tech said. I will also call a dealer on Monday and have them check if there's a recall or TSB.
wcgman is offline
Old 08-04-2013, 06:38 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
No problem. I'm looking forward to hearing what they tell you. (my 8.8 acts a little sketchy sometimes) Make sure you follow up here.
Old 08-05-2013, 07:26 AM
FordService
Official Ford Rep
FordService's Avatar
Hi wcgman,
Before I step in, please touch base with your Service Manager regarding the rear end. They’ll be able to let you know if work or replacement is needed and whether there is coverage available (warranty, recall, etc.).
I’m happy to take a look if you still have questions.
Thank you for the mention, UPRSarad!
Deysha
FordService is offline
Old 08-05-2013, 06:30 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Originally Posted by FordService
Hi wcgman,
Deysha
No problem Deysha. I'm glad we have you as a liaison between us and Ford Corporate.
Old 08-06-2013, 07:43 AM
FordService
Official Ford Rep
Awwwe! Thank you, UPRSharad!
Deysha
Tyoung68
08-25-2015 04:31 AM
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
Quick Reply: Rear end problems?
