S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
Power Steering Pump?
Old 04-08-2015, 03:15 AM
petrock
petrock's Avatar
Default Power Steering Pump?
My brother-in-law’s ’07 GT500 has a bad power steering pump. At idle, turning the steering wheel takes a lot of effort but its fine if I rev it to 2k. Anyway, so we went to AutoZone to pick up a new pump and the one they have listed is the wrong pump. The pump on his car mounts to the motor/head via three bolts. The one they had had 4 holes to mount the pump to the side of something. I figured it was the pump for a regular GT mustang. O’Reilly’s and CarQuest had the same pump. So where do you guys pick up new pumps for your GT500’s? Thanks...
petrock is offline
Old 04-08-2015, 06:24 AM
jwog666
jwog666's Avatar
try the dealer, it will be right the first time, because they look up parts using the VIN
jwog666 is offline
Old 04-08-2015, 09:17 AM
FordService
Official Ford Rep
FordService's Avatar
As jwog666 mentioned, you should check with your Ford Dealer, petrock. You can start by checking on our [url=http://www.fordparts.com/]Ford Parts[\url] site with his VIN. This may also help.
Deysha
FordService is offline
Old 04-09-2015, 02:13 AM
petrock
petrock's Avatar
Dealer wants $275. Thats a bit pricey for a power steering pump. Any other ideas? Thanks...
petrock is offline
Old 04-09-2015, 05:23 AM
jz78817
jz78817's Avatar
not to be snarky, but if he can afford a GT500, then he should be able to deal with the price of an OEM power steering pump.
jz78817 is offline
Old 04-09-2015, 11:51 AM
petrock
petrock's Avatar
Considering that an ‘07 GT500 is around the same price as a ’15 Mustang V6 (around $20k) according to Kelly Blue Book, yeah its a bit snarky. Not to mention that he inherited it from his fathers estate when he passed away last year. But that is besides the point...
petrock is offline
Old 04-14-2015, 12:30 AM
petrock
petrock's Avatar
Closing the loop on this in case someone else stumbles upon this thread. I picked up a reman pump from rockauto.com for $84 ($52 after core return). A-1 CARDONE Part # 20344.
petrock is offline
Old 05-17-2015, 07:33 AM
wcgman
wcgman's Avatar
Huh - I've been thinking my pump might be bad too. I bought a warranty from the CU when I refied so maybe I'll exercise my rights and have them swap one in :P Did that fix your problem with the swap?
wcgman is offline
Old 05-20-2015, 04:36 AM
petrock
petrock's Avatar
Yes, replacing the pump fixed the problem. The car turns nice and smooth now with little effort. Good luck getting your’s fixed.
petrock is offline
Old 05-25-2015, 08:14 AM
wcgman
wcgman's Avatar
I found my warranty and I put a zero deductible on it, so I just need to get it in and its a gratis fix!
wcgman is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
9550
10-26-2015 05:01 PM
uberstang1
09-20-2015 06:42 PM
rksnow1
09-14-2015 08:46 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Power Steering Pump?
