96-98 suspension
96-98 suspension
What were exactly the upgrades in the suspension for 96-98 saleen. cause my ride sucks in suspension, im trying to know what to do with it. So far i had lower it with eibach springs, tokico shucks and struts (18" rims ) im going to put cc-plates. what else do i need or the products im using are bad?
thanks for any advice
RE: 96-98 suspension
cviteri, a couple ofquestions....what Tokicos do you have....adjustable or non. Do you have the pro kit or sportline. I recommend the Bilsteins and pro-kit. The sportline springs drop the car to much! Also, did you replace the stock pinion snubber with a shorter one? Last, get yourself a set of MM caster camber plates.
Casey
Casey
Matt's 95 Stang
10-05-2015 07:16 AM
