Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
IF you own a SALEEN: 2005-2008 Extreme or Parnelli Jones - Get your DYNO SHEETS NOW!
Old 02-20-2009, 05:48 AM
  #51
sftdyna
sftdyna's Avatar
Originally Posted by Radiating
There's a difference between stroking a 4.6 and the Saleen 302 engine. You're not putting unnecessary strain on an engine that was designed from the ground up to have that amount of stress be a necessary component of it's engineering.
Here's an interesting read about the 302 being underrated:
http://www.moddedmustangs.com/forums...nderrated.html
The 5.0 magazine article isn't the one I remember reading, it must have been in a different magazine but isn't available through 5.0.
My point is that don't take info at face value, even here.
perhaps red devil could shed some light on weather or not the 302E was redesigned from the ground up!! and perhaps tell us what was done different.
sftdyna is offline
Old 02-20-2009, 08:23 AM
  #52
S281 E
S281 E's Avatar
I thought they just took the motor from the PJ cars.
S281 E is offline
Old 02-20-2009, 09:25 AM
  #53
smoothy
smoothy's Avatar
IIRC, the compression on the PJ engine is too high to allow a blower to be added, so some mods would have had to be done.
smoothy is offline
Old 02-20-2009, 10:50 AM
  #54
Red_Devil
Official Sponsor For Whiteline USA
Red_Devil's Avatar
The block is bored the same, the pistons are different because its a different compression, the heads on the Extreme are CNC ported and the PJ is not, and I believe there are different cams in the E engine as well.
Red_Devil is offline
Old 02-20-2009, 11:40 AM
  #55
AMS MIKE
AMS MIKE's Avatar
correct
AMS MIKE is offline
Old 02-20-2009, 12:36 PM
  #56
sftdyna
sftdyna's Avatar
so would you consider this a ground up redesign to reach 302ci or basicly just slightly overstroked as compared to most other kits at 298 ci? because a 281E aside of stroking has the same basic set up correct?
sftdyna is offline
Old 02-20-2009, 02:15 PM
  #57
Red_Devil
Red_Devil's Avatar
I guess. There are big differences in the 281 and 302E engines. The compression is higher on the 302 and that's how the higher hp is achieved, it's not just displacement. Also I don't believe that the 281E heads were ported. I know that between 05-06E and 07-09E they also changed some things like the rings which made initial power slightly lower until they broke in. The 302E engines also benefit from an upgraded water pump.
I'm sure the cams were probably different from 281 to 302E as well.
Old 02-20-2009, 09:35 PM
  #58
AL_TOON
AL_TOON's Avatar
Originally Posted by AMS MIKE
The 05-08 Extreme's have the Bumper number and year (ex: 06-1234E)
the Parnelli Jones have the last 4 digits of the VIN (Ex: 1234PJ)
the reason the PJ's don't have bumper numbers is because they were on the dyno before a bumper number was a assigned to the vehicle, so they were done by the last VIN numbers.
-Mike
How do I get it again? my is #36
AL_TOON is offline
Old 02-20-2009, 09:39 PM
  #59
AL_TOON
AL_TOON's Avatar
I sent the PCM back to Saleen to have it upgraded and they ended up doing it for free. It did make a difference but I didn't have the car dynoed to actually test the difference. Can't wait to see what a stock S302E dyno's at.
who the hell would you send the PCM to now?
also Im looking at another 06 extreme, how can one improve the tune?
AL_TOON is offline
Old 02-20-2009, 11:07 PM
  #60
AMS MIKE
AMS MIKE's Avatar
PM sent
AMS MIKE is offline
Quick Reply: IF you own a SALEEN: 2005-2008 Extreme or Parnelli Jones - Get your DYNO SHEETS NOW!
