Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
General 2002 Saleen Questions.
Old 03-09-2012, 03:24 PM
trueblue Saleen
trueblue Saleen's Avatar
Default General 2002 Saleen Questions.
I own a 2002 S281 and am new to saleens. I've tried looking up some general things on google and cant seem to find what I'm looking for.
First the H20 gauge on the center of dash: What should it read at normal driving and what happens/causes it fi it gets high.
Second is there any special kind of H20 coolant I can use for SC, since I have a seperate reservoir for it.
Thanks any input would be grateful.
trueblue Saleen is offline
Old 03-11-2012, 08:40 AM
coderedsaleen
coderedsaleen's Avatar
Your H2O gauge should read about 130-160 normally.
A fix would be to get a bigger heat exchanger or get your intercooler welded up so all the air will pass by it instead of going around it.
Saleen just used normal 50/50 green coolant, you can use a 50/50 Ford Gold Premium in it also. Add water wetter or purple ice to chemically cool it.
coderedsaleen is offline
Old 03-14-2012, 08:43 AM
eviligloo
eviligloo's Avatar
....or get the Chicane Intercooler which will give you the biggest help in cooling the car (also the most expensive option, though). Unfortunately the company is not longer open so you'll have to search around for used ones.
eviligloo is offline
Old 03-19-2012, 08:46 AM
trueblue Saleen
Ill probably pull the intercooler and clean it. While doing that I'll put a new gasket on between the sc and block.
cr620
10-03-2022 10:18 PM
mrtrodonet
09-19-2020 03:12 PM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: General 2002 Saleen Questions.
