Engine Knock?
Old 06-08-2011, 07:00 PM
rangerheave
rangerheave's Avatar
Default Engine Knock?
i own a 2010 Mustang GT with 8,200 miles on it. Since Ive bought it, I have added JLT CAI, Bama tune, Flowmaster axel back and 3:73 gears.
Ive noticed recently that when the tach gets to just above 4,000 RPM's i hear knocking coming from the engine. Almost like a fast ticking sound.
Assume I am the biggest mechanical moron you have ever spoken with and fill me in on possible reasons why this would occur.
rangerheave is offline
Old 06-08-2011, 08:16 PM
Nuke
Nuke's Avatar
You could be running the incorrect octane or your local fuel is suspect or your tune is incorrect or a host of other reasons. Try loading a lower octane tune or tank-up with higher octane fuel and see what happens. Remember: when trying to use a higher octane fuel, you'll need to drive about 10-20 miles before the higher octane from the tank makes it to the engine immediately after filling the tank.
Nuke is offline
Old 06-09-2011, 05:51 AM
rangerheave
Thanks for the reply. I have been hoping I may have just gotten some bad gas and not something internal to the motor. I filled up this morning with 93 Octane so we'll see how things go over the next couple of days.
Old 06-09-2011, 06:50 AM
Nuke
Nuke's Avatar
If it continues to knock with the new fuel, load a lower octane tune. It's not too uncommon for fuel in certain areas to be a bit "off" of their rated octane. It's posible you may just need to pull a degree or 2 of timing with the tuner. Altitude can play a role as well as other things. % ethanol doesn't always help, either.
Nuke is offline
Old 06-09-2011, 08:30 AM
siggyfreud
siggyfreud's Avatar
I would think ethanol would help due to its higher octane, despite its lower energy?
siggyfreud is offline
Old 06-09-2011, 08:36 AM
Nuke
Nuke's Avatar
I'm not familiar with how the guys that write the tunes deal with that; the potential to be running straight fuel vs. fuel with "up to 10%" ethanol.
Nuke is offline
Old 06-09-2011, 10:20 AM
ski
ski's Avatar
I read that E10 fuel is supposed to have the octane rating specified at the pump.
That said, it involves a mixing process, which can lead to an incorrect blend(intentional or not).
ski is offline
Old 06-09-2011, 03:36 PM
Burns331
Burns331's Avatar
I doubt its octane, i would be looking for another issue to cause the tick
Burns331 is offline
Old 06-11-2011, 12:05 PM
MurderedStang
MurderedStang's Avatar
I'm not sure if this is a correct response but I'm in FL and we have a FEW places that sell gas with no ethanol, it's more expensive but maybe you have a place where you live?
MurderedStang is offline
Old 06-11-2011, 01:01 PM
Daniel98GT
Daniel98GT's Avatar
An exhaust leak can sometimes make a ticking sound at certain rpms.
Daniel98GT is offline
Quick Reply: Engine Knock?
