What is the name of this seal coming out of the transmission?
Old 04-28-2013, 02:02 PM
Aquakitty
Aquakitty's Avatar
Question What is the name of this seal coming out of the transmission?
Hi all, getting a headache trying to figure out what seal this is. The yellow circled one, obviously. I have a 2004 GT 5 speed.
I thought it was this seal but that does not look the same to me, unless the thing circled is not the actual seal?
Also my understanding is this rear output seal is not hard to change (no need to drop tranny) right?
Tranny is Tremec 3650
Aquakitty is offline
Old 04-28-2013, 07:18 PM
Seabee1993
Seabee1993's Avatar
You'll have to drop the driveshaft, and drain the Trans, and/or just put a catch pan under either way.Its called the rear extension housing seal. Pry the old one out with a seal puller or screwdriver. Replace the seal square to the extension housing bore with a socket which should be slightly smaller than the outside diameter of the seal, tap with rubber mallet til flush. Reassemble and check fluid level and done.
Seabee1993 is offline
Old 04-28-2013, 08:15 PM
Aquakitty
Aquakitty's Avatar
Ahhh thank you much. What a pain trying to find the technical name.
Old 04-28-2013, 08:32 PM
Aquakitty
Aquakitty's Avatar
Hmm any idea which one it is? Is it the drive shaft seal?
http://www.oreillyauto.com/site/c/se...smission+seals
Old 04-28-2013, 08:52 PM
Seabee1993
Seabee1993's Avatar
TR3650/T45OD/T5OD/TR3650/T56: http://www.fordparts.com/Commerce/Pa...&model=Mustang
Theres your part#, same on all models for that year from Ford, and not much more than what you were looking at on O'Reilly. Personally I would go for the OEM part, that and I don't care much for O'Reilly much around my neck of the woods. Good luck!
Nick Oliver
10-17-2018 04:22 AM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Dragonus18
09-09-2015 01:21 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: What is the name of this seal coming out of the transmission?
