2001 mustang wont start
Old 03-24-2017, 08:18 PM
Lee Schutt
Lee Schutt's Avatar
Default 2001 mustang wont start
I have a 2001 mustang 3.8v6 gets spark and fuel but all it does is roll over some times it acts like it wants to start but after that all it does is roll over ive checked fuses fuel pump spark what else could it be please lmk ive been messing with this car for almost 2 weeks and does the same thing thx
Lee Schutt is offline
Old 03-24-2017, 10:57 PM
Daehawk
Daehawk's Avatar
If you're getting fuel , fuel at pressure , air , spark ....then my thoughts turn to timing and then computer.
Daehawk is offline
Old 03-25-2017, 11:06 AM
Lee Schutt
Lee Schutt's Avatar
cant it mess it up if i change the co.puter wont it need to be reprogramed ?
Old 03-25-2017, 11:08 AM
Lee Schutt
Lee Schutt's Avatar
computer
Old 03-25-2017, 10:49 PM
Urambo Tauro
Urambo Tauro's Avatar
How's that battery? These cars can be real sensitive sometimes, and that battery needs to be in tip-top shape (fully charged and able to pass a load test).
Urambo Tauro is offline
Old 03-29-2017, 02:42 AM
It use to be the rule of thumb with carburated engines that if you have fuel, spark/ at the correct timing , and compression it should start.
How ever with these fuel injected engines you need fuel/ at the correct pressure. Get a helper and have them spray a little starting fluid into the air intake while you crank it. If it fires up for a moment then your fuel pressure is too low. Put a pressure gauge on it and check fuel pressure. These engines need at least 30psi on the fuel rail to start, and that is low. You should see about 35-40 psi on the fuel rail.
Old 03-29-2017, 12:37 PM
movielover40
movielover40's Avatar
Agree with dawson.
movielover40 is offline
