Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Drag Slicks
Old 06-18-2008, 01:57 PM
Demon 340
Administrator
Demon 340's Avatar
Default RE: Drag Slicks
if his car is stock, he DOESNT need slicks...most stock vehicles dont have enough power to make use of a true drag slick. too many people think that slicks are the answer, but the are not.
also with a taller tire, it is not just an issue of rotational mass, but also how the taller tire effectively lowers your final gear ratio...
Demon 340 is offline
Old 06-18-2008, 02:38 PM
Blownsvt
Blownsvt's Avatar
ORIGINAL: Ride Of The Month
did you read my 2 posts where i mentioned gear ratio? also like a said in my laast post a dot cheater slick would be the best bet.
Blownsvt is offline
Old 06-18-2008, 02:48 PM
Demon 340
Administrator
Demon 340's Avatar
i wasnt correcting you, i was just being more straight-forward. to someone who doesnt know any better, your posts may just be more confusing. the rotational mass is the least of the concerns for most new racers...but some think that a slick=automatic perfect traction.
i see WAAAAAAAY too many guys at the track with slicks who dont need them...when i was a young buck, i got a set of free slicks, and i was in the high to mid 13s...with the slicks, i was in the low 14s...
Old 06-18-2008, 02:51 PM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
thats what we need to know, how much power are you putting down.......i saw a tt97 cobra go 7.83 on DR's on youtube/streetfire.
USMCrebel is offline
Old 06-18-2008, 02:57 PM
Demon 340
Administrator
Demon 340's Avatar
this was a DOT-tire only class..
http://youtube.com/watch?v=lD8rm_UN_BE
unless the OP is heavily modified, i dont see a need for slicks...
Old 06-18-2008, 03:02 PM
Blownsvt
Blownsvt's Avatar
agree you will be better of with a good DR or a DOT cheater tire. My buddy dead hooks his 450+ hp cobra with a 255 MT cheater slick. Several guys i know think they are better than the ET drags.
Blownsvt is offline
Old 06-18-2008, 03:04 PM
USMCrebel
USMCrebel's Avatar
can i get a link to the cheater slicks?
Old 06-18-2008, 03:10 PM
Blownsvt
Blownsvt's Avatar
http://www.mickeythompsontires.com/s...?item=ETStreet
Blownsvt is offline
Old 06-18-2008, 03:19 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
USMC you don't need a "cheater slick" either. They are pretty much a regular slick with some grooves cut to pass DOT regs. Get a drag radial like a BFG or even a Nitto and you will be fine. BTW a TT Cobra going 7.8's on a DR is no big deal, there are cars that in the 8's (1/4) on a dr, I run 7.4's in the 1/8 on a MT dr, N/A to boot.
JD1969 is offline
Demon 340
Administrator
Demon 340's Avatar
for anyone who doesnt know, a "cheater slick" is a slang term for the DOTs that have almost no real tread...like my hoosier quick time pros...
Quick Reply: Drag Slicks
