First time out with cam only T/A
#41
Nope. It depends on race weight and suspension. I have a friend who has a stock cam/internal car that runs low 11's/high 10's. Yes he has every bolt known and a lot of weight reduction, but the point is the car makes very little power for what it runs.
#42
By the same token, I've seen cammed LS1 cars run mid 12s with only minimal bolt-ons (maybe just intake and exhaust) and full weight.
The low 10 second 383 stroker car I mentioned earlier went 11.76 with no engine work at all, just external bolt ons and some weight loss (but not much). Still had 3.23 gears, full interior, AC, etc.
#43
In your experience, will your average cam only LS1 car be faster than a bolt on LS1 car? I'm talking the rule, not the exception. I'm sure you could find a S197 GT that is bolted on and completely gutted that will run faster than your average blown S197 GT. But that's an exception more than the rule.
But I defer to you. You've forgotten more about cars than I know (that's a complement, in case you read that wrong). I always thought in the LSx world that a "cam only" car was a set up from a bolt on car. I guess I was wrong.
#44
Generally speaking, an owner will put some decent external bolt-ons on a car before opening up the engine and swapping the cam, heads, etc. Usually, but not always. So generally speaking a car with a cam swap should be a bit faster.
#45
That's what I would have thought. Thanks, Tommy.
Luke9222
10-22-2015 11:55 PM
mungodrums
10-07-2015 04:01 AM
