Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Kerns vs Subaru Legacy Spec B
Old 02-19-2012, 11:35 PM
Kerns
Kerns's Avatar
Default Kerns vs Subaru Legacy Spec B
So this weekend I decided to head out and have a little fun. One of the races I had was vs a Subaru Legacy Spec B. I didn't know much about the car before the races and just had heard that it was pretty quick. So we decided to line them up. All in all we did 7 races. 4 40 rolls, 2 60 rolls, and 1 20 roll. Races are as follows...
1st 40 Roll: He honks it off and I can barely hear his horn so on what I believe is the 2nd honk (really it was the 3rd honk) he takes off and instantly puts about 1/2 a car on me before I can react. I hit it and my tires are cold so i proceed to spin. He get about a car and a half out on me before I finally get traction. I shift into 3rd and start closing the gap. By the top of 3rd I am at his back bumper. I slam 4th and am closing in on his front tire when he has traffic ahead so he lets off around 110mph.
2nd 40 Roll: Same thing pretty much, I can't hear the honks, I spin a little less this time, but then miss 3rd. By the time I get back into it he is probably 1 1/2 to 2 cars up on me. I start catching up and he lets off shortly after. We talk about how I am having trouble hearing him so we decide that I will honk for the rest of the races.
3rd 40 Roll: I honk it off and we both nail it. Pretty much just stayed side by side through 2nd. I slam 3rd and I start to inch out on him a little bit. By the top of 3rd he is around my back tire. I hit 4th and then I start pulling a little harder on him. By the top of 4th I have about 2 cars on him.
4th 40 Roll: Pretty much a mirror image of the 3rd roll. Even through 2nd, slowly pull in 3rd, then pull a little more in 4th.
1st 60 Roll: I start in 3rd and honk it off. As soon as we hit it I slowly start to pull on him around the same rate as from the 40 rolls. By the top of 3rd I have almost a full car on him. By the top of 4th I have a 2 cars on him and we shut down.
2nd 60 Roll: Mirror image of the first one.
20 Roll: Higher rolls are usually better for me, and because he is awd we decided to do a low roll for him. We slow down to 20mph and I down shift into 1st. I honk it off and luckily for me, because of the previous races my tires had heated up. 3... 2... 1... we both nail it and I jump out a little on the hit. By the top of 1st I have 1/2 a car on him. I slam 2nd hard and luckily get traction. Through 2nd I put another 1/2 a car on him. I hit 3rd and put another car on him. Slam 4th and put 1 more car on him before we shut down with me up 3 cars. There was a guy in an 07 Cobalt SS that actually recorded the 20 roll from up ahead.
Here is a video of the race:
http://www.youtube.com/watch?v=gTkTg...ature=youtu.be
I actually also found his car online so here is a picture of the car, and for anyone interested in his mods they are as follows:
Engine Specifications:
  • EJ255 380 WHP 351 WTQ on 92 Octane
Engine:
  • Group N Engine Mounts
  • Unorthodox Racing Light Weight Crank Pully
  • Unorthodox Racing Light Weight Power Steering Pully
  • Gates Micro V Belts
  • Denso Iridium Plugs
  • Zero Sports 71C Thermostat
  • Zero Sports Radiator Shroud
  • Perrin Radiator Hoses
  • Perrin Dual Oil Catch Cans
  • Subtle Solutions Alternator Cover
  • SPT Billet Oil Cap
  • SPT Battery Tie Down
  • Optima Red Top Battery
  • Hella Supertones Painted DGM
  • RPA Hood Dampers
  • Koyo Aluminum Radiator
  • STI Radiator Caps x2
Turbocharger & Induction:
  • Blouch 20G XT (7cm Hotside)
  • Prosport Turbo Heat Shield Blanket
  • Tial MVS 38mm VTA EWG (.9 Bar)
  • STI Intake Manifold
  • JDM TGV Deletes Ported and Polished
  • Perrin FMIC
  • Turbo XS RFL VTA BOV
  • Perrin Inlet Hose
  • Apexi Shortram Intake
Fuel & Tuning:
  • Walbro 255lph Fuel Pump
  • Deatsch Werks 850cc Injectors
  • Cobb Access Port 2.0 Tuned by Tim Bailey at PIA
Exhaust:
  • Tomei Expreme Unequal Length Headers Wrapped and Coated
  • IAG Performance Custom Up Pipe Wrapped and Coated
  • Perrin Two Piece Catted 3" Downpipe
  • Perrin 3" Mid Pipe
  • Perrin 3" Y Pipe
  • Perrin Sport Tone Mufflers
  • Rallitek Exhaust Hangers
Drivetrain:
  • Exedy Twin Plate Clutch Kit
  • AP Braided SS Clutch Line
  • Motul RBF 600 Dot 4 Clutch Fluid
  • Group N 6 Speed Transmission Mount
  • Cobb 6 Speed Short Throw Shifter
  • Cobb Hardened Shifter Bushings
  • Cobb Hardened Rear Shifter Bushing
  • Redline Light Weight Shock Proof Transmission Fluid
  • Redline 75w/90 Rear Differential Fluid
Brakes:
  • DGM Brembo Calipers Front
  • DBA 4000 Slotted Rotors Front
  • Hawk HPS Pads Front
  • DGM Brembo Calipers Rear
  • DBA 4000 Slotted Rotors Rear
  • Hawk HPS Pads Rear
  • Techna Fit 6 Piece Custom SS Brake Line Set
  • Motul RBF 600 Dot 4 Racing Brake Fluid
Suspension, wheels & tires:
  • Sti Front Strut Bar
  • Cusco Rear Strut Bar
  • Jspeed Inner Front Fender Braces
  • Perrin 25mm Front Stabilizer Bar
  • Perrin Front Endlinks
  • Perrin 25mm Rear Stabilizer Bar
  • Perrin Rear Endlinks
  • Perrin Rear Stout Mounts
  • Cusco Front Lower Arm Bar Type II
  • Cusco Rear Lower Arm Bar Type II
  • Cusco Rear Side Power Braces
  • Cusco Rear Lower Power Brace
  • AVO LCA Front Bushings
  • AVO Steering Shaft Bushings
  • BC Racing BR Series Coilovers
  • Summer 18x8 +48 O.Z. Racing Alleggerita HLT's
  • BF Goodrich 235/35ZR18 g-Force T/A KDW NT's
  • Winter 18x8 +47 Drag DR-38's
  • Falken 235/40R18 Eurowinter's
Interior:
  • Greddy Turbo Timer
  • Greddy Boost Controller
  • Defi Link System
  • Defi Amber Red Boost Gauge
  • Defi Amber Red Water Temp Gauge
  • Defi Amber Red Oil Temp Gauge
  • Defi Amber Red Oil Pressure Gauge
  • Defi Amber Red Exhaust Temp Gauge
  • JCS Pods Dual A-Pillar Gauge Pod
Exterior:
  • COC Carbon Fiber Front Lip
  • R-Rev Carbon Fiber Grill
  • R-Rev Eyelids Painted DGM
  • R-Rev Carbon Fiber Fog Light Bezels
  • R-Rev Rear S Type Spoiler
  • K2 Rear Window Spoiler
  • Sti Black License Plate Frame
  • Cleared and Blacked Out Headlights
  • DRL Delete
  • Windows Tinted to Legal Limit
  • DeBadged All Except Trunk Emblem
  • Gorilla Aluminum Tuner Lug Nuts Black Anodized
  • Lamin-X Smoked Tail Lights
  • Rolled Fenders Front and Rear
Kerns is offline
Old 02-19-2012, 11:43 PM
The Stig
The Stig's Avatar
Good Races! That's awesome that you pulled on him from 20.
The Stig is offline
Old 02-20-2012, 06:52 PM
Kerns
Kerns's Avatar
Yeah, I was pretty surprised that I was able to hook from the 20 roll based on how bad I was spinning on the first 2 40 rolls. Its amazing how much better traction is when your tires are heated up.
Kerns is offline
Old 02-20-2012, 06:58 PM
ctgreddy
ctgreddy's Avatar
awesome race kerns! that subie looks sick tho. at first it didn't sound like it was modded and i was reading the races and like, wtf those things must be super subies to be keeping up with kerns. lol then i see the extensive mod list and whp. good job man.
ctgreddy is offline
Old 02-20-2012, 07:20 PM
Stone629
Stone629's Avatar
I want that Legacy! Damn Kerns, you had your hands full with that Subie, but sounds like you did work and handled him. I bet he's deadly at the track. Nice work!
Stone629 is offline
Old 02-20-2012, 07:22 PM
z28th1s
z28th1s's Avatar
Good runs!
z28th1s is offline
Old 02-20-2012, 07:33 PM
ctgreddy
ctgreddy's Avatar
I dunno about that, if they have similar trannies as the wrx's they're super week and he cant really launch it. but now looking at the mods list it shows a 6 speed so it's prolly stronger.
ctgreddy is offline
Old 02-20-2012, 08:11 PM
97tplsGT
97tplsGT's Avatar
Very nice runs! Two very sexy cars, each in their own rights....
97tplsGT is offline
Old 02-21-2012, 04:00 PM
Mishri
Mish-ogynist
Mishri's Avatar
Haha, i've noticed the subaru crowd (and i'm sure other groups do too) really like posting every little thing they do to their cars on their mod lists...
really, who puts radiator hoses and oil caps down for a mod? haha... ahh.. well...
Mishri is offline
Old 02-21-2012, 06:30 PM
turbo 2.8
turbo 2.8's Avatar
good runs! lol when I look at his mod list all I see is dollar signs! clean car though.
turbo 2.8 is offline
Quick Reply: Kerns vs Subaru Legacy Spec B
