air shocks
I think he's only looking for a little more rear ride height, possibly to clear tires that may be getting pushed outward with wheel spacers (that a separate thread suggests he might be thinking about).
I'd really rather see a ride height issue corrected with either the right (i.e. longer and/or stiffer) springs or adjustable spring perches. I don't have it handy, but I think that Mathis' Mustang Performance 2 book has plans for a LCA mod to do this.
And wheel/tire position issues should be corrected with wheels of the necessary offset without putting the tires at or out past the sheetmetal.
Norm
Norm
No offense to ovenman, just that some posts or threads I see are red flags for doing a little background research first. Happens fairly frequently, actually.
Spacer thread.
Another more-than-likely-related thread.
Norm
Spacer thread.
Norm
What tires are you currently running (all three numbers please) and what wheels are you running (if not OEM, I need off-set/diameter and width). Take a look at your other two threads Norm linked above
Jazzer
EDIT: Thanks, Norm, but was actually refering to the OP giving some background info
Jazzer
Last edited by Jazzer The Cat; 06-06-2011 at 12:02 PM. Reason: Givin' props to my pepes!
daltron
04-28-2016 08:10 PM
