Improve Stock Suspension
#31
So I would like to make the roll a little slower. And overall a stiffer ride. If I'm understanding you correctly?
BTW, there's a difference between "stiffer" meaning "firmer" and "stiffer" just being harsher. A lot of the difference is in the shock/strut choice.
Norm
#32
Norm
#34
Alright thanks yeah I'm really interested in the AX now that it has been brought to mind. Lol. I'm gonna look up a place near me now.
Thanks for all your help. I think out of all the people that I have seen post on here, you seem to be the funniest and one of the most friendly and I love your car btw. I wanted a white one.. LUCKY! :P
I think you will enjoy AX, if you are into the "feel" of a sudden change in latteral direction. I dig 'em hard and love the sensation of defying physics by turning the wheel and my car efforlessly changes direction
Jazzer
#36
My AX club charges about $35 a year and $35 per race-day. It is a work/run event, but may not be in your case.
1.5" is about the cut-off point for the need to install CC plates. Increased negative camber is the result of dropping, as you probably already know, but will be helpful on corners and AX. You will get some additional inner-tire wear, as you will probably be in the neighborhood of 1.25° with such a drop. Hopefully Norm will chime in with a more exact number, as he is that kinda guy
Jazzer
Jazzer
#38
Negative camber helps keep more of the tire on the surface of the road as body roll would otherwise put the tire up on its outter edge (simple explanation) Adding caster tilts the strut back to help in the same way while the wheels are turned (again, simple explanation). I think I have some additional details in my suspension guide, but I forget... lol
Do some research on the net and will likely find some .gif images and a better description as mine pretty much sucks
Jazzer
Jazzer
#39
If you actually do end up at -1.2° and you are a moderately enthusiastic about your cornering much/most of the time, you may not need to correct your cambers.
But once you are at the point where camber correction might become necessary you can set them to what suits your own driving. And that's going to vary some depending on the individual driver as well as on the rest of the car's suspension setup.
A milder driver would probably be better off at something between -0.75° (which is the OE preferred number) and maybe -1°. A really mild driver who only cruises the car or takes in car shows might even want to set slightly less.
A driver who drives the corners consistently a lot harder than most might be able to use more than -1.2°, but do that because the tires are telling you to with outside shoulder wear (not because you'd like to think you drive that hard).
For any given driver and average driving, a stiffer suspension won't need camber to be quite as negative as a softer suspension would.
Norm
#40
I could imagine that when I lower it that I may take corners harder as I will want to play more. But right now I'm a fairly mild driver except when those slow pokes get in the way. Then I get annoyed and become more aggressive or if I'm just looking to mess around. So I guess I can just get an adjustable plate and hopefully be able to find my sweet spot. Wherever that may be.
