Suspension Ask all of your general suspension questions here!
Suspension Wars - Episode 1 :)
Old 04-23-2012, 03:10 AM
Forty-two
Forty-two's Avatar
Default Suspension Wars - Episode 1 :)
hi all
i'm planing my suspension mods right now and have been reading a lot already. my first step is the following:
- kony yellows
- steeda sport springs
- cc plates
my stang is a daily summer driver and i'm not racing. i only want better suspension and slight lowering. it's already munching my front tires on the inside even at stock height so it surely won't get better with an inch drop. seems like the shop where i changed my lower a-arms didn't do the alignment very well. so cc plates are a must because of lower springs (in addition to the weakness of the stock strut mounts).
i'm considering the steeda hd mounts, but am ready to spend 50 bucks more for the mm if i really need caster adjustment for my ride. of course i'm not sad if i can get some alternative for less.
anybody who can enlighten me?
thanks a lot
nick
Forty-two is offline
Old 04-23-2012, 07:20 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Caster can be a nice adjustment for improved cornering and especially if you have wider than OEM wheels/tires. If you are looking for improved cornering or feel you may at some point, spend the extra money and gain the adjustability of an aftermarket CC plate.
Jazzer welcomes forty to MF's
Jazzer The Cat is offline
Old 04-23-2012, 09:43 AM
Forty-two
Forty-two's Avatar
Thanks for the welcome
I'm aware of the fact that I need adjustable plates, as the car will be lowered a bit with the Steeda springs. Just didn't know if I need the more expensive ones by MM or if the Steeda HD would be sufficient.
My pony is running on 245/35/20 and 285/30/20
Old 04-24-2012, 06:29 AM
Jazzer The Cat
Retired Moderator
It can only be an advantage to run a CC plate that allows a wider range of adjustment, so I would get the plates that allow just that.
Jazzer
Old 04-24-2012, 08:13 AM
Forty-two
Forty-two's Avatar
Thanks for the input Jazzer.
Now waiting for a response from Stang Mods regarding my shipping costs
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Florida Regional Chapter
09-30-2015 08:04 PM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Suspension Wars - Episode 1 :)
