Lowering springs and tire wear
I'm looking for help again. I am a neophyte and everything is a learning experience for me. After researching I found that most people believed that if you only lowered the front end by 1 inch that you would not have issues with tire wear (2011 GT). I lowered the front 1 inch and the back 1 1/2. Six months later I have excess tire wear on the inside of the front tires. I took it in for realignment and everything is as it is suppose to be.
Is there an easy solution, without caster/ camber plates? If anyone has dealt with this I would appreciate some advice. Can we adjust the camber outside of normal specs to address the problem? How much?
As always, thanks for the help.
Thanks Jazzer! I've come to the conclusion that CC plates are the answer. Just wish I had known that when I was doing the initial spring install. Would have saved a great deal of time and effort on my 68 year old body. I mostly installed them for the looks. Is it worth trying the camber bolts first to see if they will allow for enough adjustment? I will not be taking my car to the track.
Thanks again. Jrcabe
All this said, camber bolts will certainly be the least expensive and most direct way to address the issues you have.
Jazzer
Lowering with just the springs will cause excessive camber and uneven tire wear up front, that is why we use our strut mounts, in addition to being stronger they have room for camber adjustment, the stock ones don’t.
Great American piece that will definitely help you with your tire wear - http://www.steeda.com/store/steeda-2...ut-mounts.html
Let me know if I can help you get a set ... you can reach me at tim@steeda.com.
Best Regards,
TJ
Best Regards,
TJ
09-08-2015 11:50 AM
