Am I missing Anything??
Im upgrading and replacing my suspension-Heres whats getting replaced-
Rear Suspension: Shocks, Springs and Insulators, steering damper shock, Tubular Upper and Lower control arms.
Front Suspension: Lower Control arm bushings, Lower Ball Joint, Tie Rod, Sway Bar Links and Bushing, Struts, Springs and Insulators.
Question am I missing any suspension parts that should be replaced while I'm doing this stuff?
Looks good. By "steering damper shock" I assume you mean quad shock? Upgraded LCA's like the Maximum Motorsports eliminate the need for a quad shock. Its actually arguably useless, it was put in to get rid of wheel-hop but I took mine out when I had stock LCA's for tire clearance and I didn't even have wheel hop. It's on a case-by-case basis so just see for yourself.
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
