Suspension Ask all of your general suspension questions here!
Would subframe connectors decrease value?
Old 12-28-2015, 08:59 PM
Chad1140
Chad1140's Avatar
Default Would subframe connectors decrease value?
I have a completely original, or original parts, 5.0 vert in great shape, that handles less than perfect even though all components seem to be in great shape. What is the forums general consensus in adding weld in sub-frame connectors decreasing a vehicles value on a very low mileage car. Would I be better suited to putting in energy suspension poly bushings or frame stiffening? especially as far as keeping it closer to orig. I know there are bolt on sub-frame connectors, but hear they really need to be welded in to take advantage of increased rigidity. Thanks for any input.
Chad1140 is offline
Old 12-28-2015, 11:57 PM
Urambo Tauro
Urambo Tauro's Avatar
Welcome!
As much as these cars benefit from SFCs, I would not worry one bit about it affecting the value. In fact, I'm inclined to consider them a necessary first mod. The only way they'd decrease the car's value is if the wrong ones were installed, or were installed improperly.
The full-length weld-in ones are indeed the way to go. Bolt-in ones are very tempting, as most of us don't own a welder. But that's a waste of time IMO. A shop with an experienced welder on-hand is likely to charge somewhere in the neighborhood of $100 labor for installation.
If you intend to keep the car close to original, don't be shy to upgrade the unseen components to improve driveability.
Urambo Tauro is offline
Old 12-29-2015, 08:38 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I agree completely, don't worry about wrecking the originality of Foxbody Mustang, regarding sub-frame connectors anyways. I don't think the Foxbody will ever reach that level of collectability.
Of course........don't blame me if your does lol.
Good luck
88 orangepeel notch is offline
Old 12-29-2015, 10:41 AM
movielover40
movielover40's Avatar
The car is not that rare so I wouldn't worry about decreasing value.
If anything it should help value.
movielover40 is offline
Old 01-23-2016, 03:26 PM
Scott2
Scott2's Avatar
Not a Fox or a vert, but I put weld in sub frame connectors on my S197 and they are great. The whole side of the car can be lifted with a floor jack on the sub frame connector.
Scott2 is offline
QuentinBenac
01-27-2016 07:53 AM
nnn
12-31-2015 02:48 PM
davidylyl
5.0L V8 Technical Discussions
12-28-2015 04:28 AM
Cha0tic
12-24-2015 05:26 PM
Boostaddict
Lethal Performance
12-23-2015 09:57 PM
Quick Reply: Would subframe connectors decrease value?
