SVT Forums
IRS gong bad in 99 cobra I suspect the carrier bushings are bad
Old 01-17-2007, 03:56 PM
99Coby
99Coby's Avatar
Default IRS gong bad in 99 cobra I suspect the carrier bushings are bad
I have a 99 cobra with the IRS. The symptoms of the problem is that every time I up shift or any time punch the gas even the slightest bit the rear end clanks. the U Joints are like new and everything looks fine. I have read that the differential bushings are known to go bad on this newly designed rearend. My question is has anyone on here had the same probs and if so what were the symptoms and what did you replace and whether that fixed your problems. Thanks for any input
99Coby is offline
Old 01-18-2007, 08:43 PM
michael12203
michael12203's Avatar
Default RE: IRS gong bad in 99 cobra I suspect the carrier bushings are bad
yes i had the exavt same problem, about a month or 2 ago my rearend started clunking real bad when i would hit the gas and let off or when i would change gears. I bought another 4.10 and had my mechanic check it out and he said my diff bushings were bad, so i got another set polys and put then in and has been fine ever since.
michael12203 is offline
Old 01-19-2007, 05:19 AM
99Coby
99Coby's Avatar
Thanks for the input ive got some quotes on having new ones put in but i was just wanting a second opinion before having the rearend pulled out. by the way how are those 4:10's as opposed to the stock gears.
99Coby is offline
Old 01-19-2007, 01:37 PM
michael12203
a world of difference, it pulls very hard, and i would not go with anything under a 4.10. I put those bushing in myself in about 30 mins. I done one at a time, pulled the bolt the bushings came right out put the new ones in and put bolt back in, the easiest thing that i have done to the car.
Old 01-20-2007, 05:22 AM
99Coby
99Coby's Avatar
What all did you have to do to put those bushings in.
99Coby is offline
Old 01-20-2007, 07:47 PM
michael12203
i jacked one side of the car up and got under it loosened one bolt at a time and took the old bushings out put the new ones in and tightened it back. then i done the other side, did not have to loosed the springs or go throught the hassle that the instructions said, it went really easily,.
Old 01-21-2007, 01:27 AM
99Coby
99Coby's Avatar
thanks for the help sound like an easy fix. Took it to a dealership a couple months back and they said the rack and pinion carrier was bad and total estimate to fix was 1500$ so this is all great news to me. Also was curious how your car respponded to the diablo predator.
99Coby is offline
Old 01-21-2007, 12:30 PM
michael12203
very well, i actually went a couple months ago to my uncles performance shop and he gave me the 101 on tuning with it. My car was really rich so after leaning it out a little, it is very strong, big big difference.
Old 01-21-2007, 12:52 PM
hawkti
hawkti's Avatar
where's a good site to get those bushings?
I got a 01 about a week ago and noticed the same thing you guys are talking about. When I shift it into gears, no prob, but when I get on the gas, I hear a little clunk. I was thinking that it was the u joints. Jacked it up and they were tight. I was then thinking that it must be the gears clunking, but reading this, I'm gonna check those out.
hawkti is offline
Old 01-21-2007, 02:50 PM
hawkti
hawkti's Avatar
I did my own research and found out I can get these things anywhere, which is sweet. However, I still have that question about the gears.
hawkti is offline
Quick Reply: IRS gong bad in 99 cobra I suspect the carrier bushings are bad
