SVT Forums
Please help me!
Old 04-08-2013, 05:53 PM
ford4life13
ford4life13's Avatar
Default Please help me!
Ok, so i have a 1998 mustang cobra, 85k miles on engine tranny, 172k on the body. When i get on it in any gear, it will bog down at around 3500 rpms. It just wont go anymore. iv already changed the spark plugs, wires, and fuel filter. i have also run octane boost and fuel injector cleaner through it. i cant seem to figure out what to replace next. Any suggestions??
Thank you!
ford4life13 is offline
Old 04-08-2013, 06:47 PM
edwin108
edwin108's Avatar
Are the catalytic converters the original ones? They may be clogged after 172k miles. Here's a video on diagnosing cats:
edwin108 is offline
Old 04-08-2013, 09:14 PM
ford4life13
yes, i just had a new set put on before i bought the car so it would pass inspection in my state and i took it to a local muffler shop just to make sure there wasnt anything holding back my airflow in my cats or mufflers.
Old 04-08-2013, 09:26 PM
ford4life13
if i accelerate slowly it will rev all the way to the rev limiter, but if i get on it at any rpm or gear it will bog down and not want to keep going past 3500 rpms.
Old 04-08-2013, 10:22 PM
edwin108
edwin108's Avatar
The only things I can think of are low fuel pressure or dirty IMRCs. See these threads:
http://www.allfordmustangs.com/forum...-problems.html
http://forums.corral.net/forums/svt-...many-pics.html
edwin108 is offline
Old 04-08-2013, 11:57 PM
ford4life13
thanks, hopefully il try to get this done tomorrow, it certainly seems like an all day job for me.
Old 04-09-2013, 07:39 AM
BraMas
BraMas's Avatar
I'm 99.99% sure you need to either clean or delete your IMRC's they are supposed to open @ 3250 rpms.
BraMas is offline
Old 04-09-2013, 08:31 AM
ford4life13
how do i delete them? is it faster than cleaning them?
Old 04-09-2013, 08:59 AM
edwin108
edwin108's Avatar
MMR makes delete plates: http://www.modularmustangracing.com/prod_dohc.htm
IMO it would take roughly the same amount of time as cleaning them as you still have to take apart your intake.
edwin108 is offline
Old 04-09-2013, 11:10 AM
Timspony
SVT Section Moderator
Timspony's Avatar
Any codes?????
Timspony is offline
