i have an 03 cobra and It ran hot I changed the thermostat water pump and the radiator cap but it still over heats...it has over a 130,000 mls on it... i'm almost out of things to check before I take it to a shop.what other options should I try before it goes to get checked out and fixed?
Water came from the radiator. It was flushed first. The water pump is new the thermostat
Is also new. There was a little steam came from the exhaust maybe once
The crossover tube stays full..the air has been let out every time it over heats. When the car is at idle the water in the radiator doesn't boil or move. After I drive it around the block then water comes out of the radiator.
