Here she is fresh off the rack from Discount Tire, need to install the Eibach Pro Kit as soon as possible. The wheels are 20x9 all the way around with 255/35/20 tires. I know most of you would prefer wider rear wheels and tires but I couldn't pass up the deal I got on this set. Any ideas on where to get the Eibach Pro Kit installed?
There is a Mustang shop over on Hwy 3 near Nasa Rd One but it's an easy install. The rear is real simple but the front is trickier because you have to decompress the springs, but it is possible to do without even using a spring compressor. If you don't know what you are doing, though, I wouldn't recommend the job as the forces at work can be dangerous. I've had the suspension apart numerous times to replace strut bearing but that's another story (track use).
Thanks for the advise, I decided to take it over to Strictly Performance in Pearland, for the price it's worth my time not to mess with it on my own. I will post some pics when it's all done.
