Switching to a squared setup, need help
16 GT PP
I want to switch to a squared setup for both Summer and Winter - I don't track this car and I live in the city in the Midwest. After the P Zeros wear out I'll switch to something more economical, but here's my plan until then and it should set me up to save money on tires in the long run. I just need to know, does it work?
Summer Setup
Front: 19x9.5 - Pirelli P275/40ZR19 P Zero - 5mm spacer
Back: 19x9.5 - Pirelli P275/40ZR19 P Zero - no spacer
Winter Setup
Front: 19x9 - BRIDGESTONE BLIZZAK LM-32 P245/40R19 98V XL - No spacer
Back: 19x9 - BRIDGESTONE BLIZZAK LM-32 P245/40R19 98V XL - No spacer
Is a 5mm spacer enough clearance? I've seen conflicting reports on multiple forums.
5mm spacers
http://www.ebay.com/itm/2-WHEEL-HUBC...5XumFX&vxp=mtr
7mm spacers
http://www.ebay.com/itm/2-WHEEL-HUBC...lXumFf&vxp=mtr
10mm spacers
http://www.ebay.com/itm/2-WHEEL-HUBC...pXumFm&vxp=mtr
Regardless of spacer size, do I need new studs? I don't know anything about studs, so if I need them are there that are good out of the box?
Another forum member started talking about knurling and lost me'
Summer Setup
Winter Setup
5mm spacers
7mm spacers
10mm spacers
Only one stud 6-10mm longer vs stock and will require dressing knurl on bench grinder.
Stock studs are 49.9mm with 0.625 knurl. cut n paste from phone notes:
610-435 57.94mm 0.628knurl
610-509 73.4mm 0.627knurl
610-437 76mm 0.628knurl
610-530 78mm 0.626knurl
610-333 90.5mm 0.625knurl
doubleoh
07-30-2016 06:43 PM
