The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Notch vs Lighting?
Old 03-10-2011, 09:53 AM
Stang562
Stang562's Avatar
Default Notch vs Lighting?
Hey I was wondering how iI would stack up against a stock lighting. This guy at the local is so cocky and talks a lot of smack and I want to shut him up. I know Lightings can be really quick modified. i have an 87 Notch with GT40 heads, GT40 upper and lower intake, udp, hedman shorty headers, o/r hpipe, e-cam, 3.73s, a/c-smog delete and a few other small things here and there. I really dont know were I stand since I havent gone to the track or really run as much as i use to. Any ideas?
Stang562 is offline
Old 03-10-2011, 01:06 PM
89LX Coupe
89LX Coupe's Avatar
Are you talking about the track, the street, from a roll or a dig??? are you on drag radials what gears do you have?
From a dig on the street I think you will have your hands full with out a doubt, from a roll I believe you should get him but you never know.......
89LX Coupe is offline
Old 03-10-2011, 01:13 PM
97tplsGT
97tplsGT's Avatar
OP said he has 3.73s. But def without a tire you'll have a fight from a dig. A roll would be interesting too because the truck already has its weight moving... kinda takes that out of the equation a little.
Def get a vid.... we need some action around here!
97tplsGT is offline
Old 03-10-2011, 01:51 PM
mrtstang
mrtstang's Avatar
It will probably be close, but if you can drive, and your car runs good for what it has, i say you have the edge here.
mrtstang is offline
Old 03-11-2011, 09:19 PM
Stone629
Stone629's Avatar
I like the Fox's chances. Not saying its the best combo in the world with all that GT40 stuff and an E-cam, but stout non the less. From a dig, both are going to struggle.
Stone629 is offline
Old 03-14-2011, 02:45 AM
302army187
302army187's Avatar
Ive seen gt40 stuff in the 12's with the right driver.
you have the edge on a STOCK lightning. If I remember right they run mid/high 13's stock.
302army187 is offline
Old 03-14-2011, 06:02 AM
95Five-ohh
95Five-ohh's Avatar
Damn 13's?? That's ****ing moving for a truck!
95Five-ohh is offline
Old 03-14-2011, 07:50 PM
302army187
302army187's Avatar
and a boing 737 weighs 27,000 pounds, but has a top speed of around 530 miles per hour.
you put enough power in anything, and it will be quick.
Old 03-15-2011, 12:10 PM
S8ER01Z
S8ER01Z's Avatar
Can't remember the exact switchover (01 i think) but the earlier models ran high 13s/low 14s... the later models would go as low as 13.3 stock (traps around 103mph)...
Edit:
http://www.dragtimes.com/Ford-F150-L...lip-10773.html
S8ER01Z is offline
Old 03-15-2011, 03:13 PM
Stang562
Stang562's Avatar
Well I am suppose to run this guy on thursday and I will be running on DR.. I will post vids up! The guy before me that owned the stang said it has a f-cam, had some internal work done, and ran low 8s in the 8th mile on slicks. But im not too sure.
Stang562 is offline
Quick Reply: Notch vs Lighting?
