The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Island dragway
Old 07-23-2012, 01:17 PM
slickman
slickman's Avatar
Default Island dragway
UPDATE 9/5, Date changed to OCT 6
Not sure how many of you are around that track but, it looks like Oct 6 weekend. I'm going to have a grudge race with a 68 Nova. I know Island dragway is not the best but, I don't care what tack it on. I can keep you up to date on the details, just post here and let me know your going.
Thanks.
slickman is offline
Old 07-23-2012, 01:25 PM
Jas5
Jas5's Avatar
Good luck! Do you plan on getting some DR's or slicks (with smaller wheels) out back so you can make use of that 505 whp? I can imagine those 20's just spinning away
Jas5 is offline
Old 07-23-2012, 01:38 PM
slickman
slickman's Avatar
Yeah, I had an extra set of 17 inch rims so I got a new set of MT ET streets for them.
slickman is offline
Old 07-23-2012, 05:16 PM
daredevil95
daredevil95's Avatar
Sept seems like a long way off, I'll be at Englishtown this wed night, what's the 68 Nova have done to it??
daredevil95 is offline
Old 07-23-2012, 06:10 PM
slickman
slickman's Avatar
The nova has a brodix 468 with a out 650 hp
slickman is offline
Old 07-23-2012, 06:22 PM
daredevil95
that's a 454 punched out 30 over with Brodix heads/intake....Hmmm, that might be a tough one? From experience, anything with a Brodix setup usually runs 10.50s or better. A lot depends on what compression he has as to what type of heads he is running, Brodix has a wide variety of heads based on Bore/stroke/compression, either way, any car that runs Brodix is usually fast! Good luck and post a vid of the race!!
Old 07-23-2012, 08:14 PM
slickman
slickman's Avatar
He has 12/1 compression and we have both driven each others cars. He told me he needed all the help he could get to take me. I felt after driving his car, its going to be close. He had 4:56's and an auto. I have 3:55's and a 5 speed. He should take me out of the gate but i should be able to run him down.
I'll be running it all out. Been practicing speed shifting. I have 1st to 2nd down. Still working on 2nd to 3rd. The last time i did any speec shifting was at the track 35 years ago!
slickman is offline
Old 07-23-2012, 08:57 PM
daredevil95
12:1 compression makes a BB run good, my kind of car. Looks like you have plenty of time to practice your shifts between now and sept, hope you pull him in the big end...good luck!!
Old 08-09-2012, 08:27 AM
uberstang1
Chupacabra
uberstang1's Avatar
Id like to come out for this, island is cose to me, but honestly man that Nova got you covered big time I think, 4.56, auto, big cubes. That car sounds setup for the strip, and sounds like a low 10 second car. With your power level,weight, only 17inch rims with radials, and a mild street setup suspension your probably going to be running mid 12s, maybe low 12s. How much track expereince do you have? I dont know why you would think your going to pull on the top end, his car has 150 horsepower on you and a boat load of torque. If theres any money on this race I have a feelign your being played.
uberstang1 is offline
Old 08-09-2012, 08:36 AM
slickman
slickman's Avatar
How do you figure he has 150hp on me? He has 650hp at the crank and I'm at 600.. 50hp looks like to me.. Oh, and his car is 250 lbs heaver then mine.
slickman is offline
Quick Reply: Island dragway
