Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
Should I get a tuner?
Old 05-14-2011, 11:20 AM
vargas
vargas's Avatar
Default Should I get a tuner?
I have K&N CAI and flowmaster mufflers. Would buying a tuner really improve numbers WORTH the price for the tuner or am i better off leaving the car un-tuned for now?
If you do recommend a tuner; which should i get? i own a 97 GT. Romeo engine/2V/4.6L/automatic.
vargas is offline
Old 05-14-2011, 02:50 PM
usmcsni
usmcsni's Avatar
what do you plan to do with the car leave it NA or go FI and what other mods do you have planed
usmcsni is offline
Old 05-15-2011, 11:57 AM
vargas
vargas's Avatar
I plan to leave it NA. Other mods for the future are throttle body and plenum, 4.10 gears, slotted/cross drilled rotors. This wont be for another while though (months).
on another note; are you in the Corps?
vargas is offline
Old 11-05-2011, 09:43 PM
EP2010
EP2010's Avatar
No don't buy one unless you want seriouse issues with your ride I have to take mine to the dealer to get the ecu reflashed . Sct tuner didn't save my stock tune properly . And the bama tunes are crap had a crappy idle on it go from 1000rpm to 600 rpm kept jumping around
EP2010 is offline
Old 11-06-2011, 01:56 AM
aerbourne
aerbourne's Avatar
^dont listen to ep2010...hes retarded. youre going to need to get tuned with those mods eventually, might as well get it now. even aside from those though, i would recommend a tuner. especially for an automatic
aerbourne is offline
Old 01-13-2012, 07:34 PM
redhotride
redhotride's Avatar
It's worth getting the tuner if your tinkering with your vehicle alot, and they can always be resold if you change your mind about all of that.
redhotride is offline
Old 01-16-2012, 09:26 AM
Mike@DiabloSport
Former Sponsor
Mike@DiabloSport's Avatar
Yes, do the tune.
Tens of thousands of Mustang owners can't be wrong, a tune is one of the best single mods you can do to a late model EFI vehicle.
Thanks
Mike@DiabloSport is offline
Old 01-18-2012, 04:00 PM
lawrencecar1
lawrencecar1's Avatar
definitely go with tune. suggest sct
lawrencecar1 is offline
Old 02-09-2012, 08:12 PM
Cutting
Cutting's Avatar
Yep, custom tunes from Brenspeed or AM give you free retunes for each mod. I need to get one...
Cutting is offline
Old 02-13-2012, 05:06 PM
millfire517
millfire517's Avatar
These are some of my concerns, I just got a cat-back exhaust on it and I am going to be going to longtubes and an off-road x-pipe. My final upgrade will be possibly a Kenne Bell SC and depend on what I need possible bigger injectors also. Depending on if the setup come with that. Don't know if I should go with a tuner or just get it dyno tuned. Or in my fashion I might just get dyno tuned and get a hand held just in case.
millfire517 is offline
Quick Reply: Should I get a tuner?
