Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
SCT Tuner and new Rear Gears
Old 02-10-2013, 11:38 AM
Det.FrankBullitt
Det.FrankBullitt's Avatar
Default SCT Tuner and new Rear Gears
I have a SCT tuner with custom BAMA tunes from American Muscle. My car is a 2008 Mustang GT 5 speed manual trans with a Airaid CAI. I am having 3.73 rear gears installed next week. My question is can I reset the speedometer with the SCT tuner with ought messing up the Bama tune I am currently running or do I need to get all new tunes from Bama? The tunes I have were all written with the CAI installed. The only thing new on the car will be the 3.73 gears.
Det.FrankBullitt is offline
Old 02-10-2013, 12:50 PM
spaseghost
spaseghost's Avatar
You can change the options for just the gears.
spaseghost is offline
Old 02-10-2013, 04:19 PM
E_cox310
E_cox310's Avatar
you go to adjust options on whatever tune you are running, then you hit "select rear axle ratio"
E_cox310 is offline
Old 02-11-2013, 08:28 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
Yes, we can definitely adjust for your 3.73's. Just give the Bama team a call and they'll make the proper adjustments to your tune and send you out a revised file! This will not affect the tune itself.
-Dan
AMDanBailer is offline
Old 03-24-2013, 02:13 PM
American MotorSport
American MotorSport's Avatar
This is correct. Be aware though, on automatic cars, although this is OK, other parameters should be changed so as to not affect a/d cancel override, learned N/V of the vehicle, and other parameters. This is usually a bigger deal with the higher gear rations. This is why, on automatic cars, we usually do not enable the gear-ratio end-user adjustable option.
On manual cars, these things are a non-issue.
American MotorSport is offline
Old 04-01-2013, 11:59 PM
SidneyGT
SidneyGT's Avatar
A little of topic, but how does she feel with those 3.73 gears. I have a 08 GT manual with the Airaid CAI insert removed and I just installed a set of JBA LT headers. I'm also using a BAMA configured tuner.
SidneyGT is offline
articman
06-21-2018 11:45 PM
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
Roush05
09-10-2015 12:23 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: SCT Tuner and new Rear Gears
