clean engines?
Old 11-22-2006, 10:15 PM
hotcar
hotcar's Avatar
Default clean engines?
how can i get my engine clean?
hotcar is offline
Old 11-22-2006, 10:22 PM
FrostByte
FrostByte's Avatar
Default RE: clean engines?
wash it
dry it
FrostByte is offline
Old 11-22-2006, 10:23 PM
jovez
jovez's Avatar
just spray some degreaser on it, spray it down with a high pressure wash, making sure you dont wet any electrical components. Then you can polish the parts. Like rubber hoses and plastic parts with like armorall or sumthin. easily done. just takes a while to make sure all the grease is gone.
jovez is offline
Old 11-22-2006, 10:52 PM
hotcar
hotcar's Avatar
what electrical components should i not get wet
hotcar is offline
Old 11-22-2006, 11:08 PM
tims 88 4
tims 88 4's Avatar
well if there not supposed to get wet can you tell me how they stay dry in the rain since the underside of your car is totally open
[sm=dontgetit.gif]
tims 88 4 is offline
Old 11-22-2006, 11:44 PM
hookedonkronik
hookedonkronik's Avatar
They are designed to come in contact with water obviously because of rain, but because they are in fact electrical components of your vehicle you should just take those plastic grocery or anything and put it around
-the alternator
-coilpack
-air intake if its not in the fenderwall or if you have your air silencer removed
hookedonkronik is offline
Old 11-22-2006, 11:48 PM
africkanV6
africkanV6's Avatar
ORIGINAL: tims 88 4
[sm=dontgetit.gif]
there arent many electrical components near the bottom of the engine bay. theyre on top for the most part. and they dry off quickly anyways because of the high temp in the engine bay.
africkanV6 is offline
Old 11-23-2006, 12:10 AM
Autobadges.com
Banned
Autobadges.com's Avatar
Use some polish
Autobadges.com is offline
Old 11-23-2006, 12:14 AM
tims 88 4
tims 88 4's Avatar
common guys i know i was just kiddn around but i hose my engine alternator coil pack and everything else and i wash it someimes too if your gonna rinse it leave it runnin but if you hand wash it turn it off then after your don e l;et it dry then start it up and take er for a ride
Old 11-23-2006, 12:26 AM
johnt2k7
johnt2k7's Avatar
he says leave it running but dont run the F*** out of it then expect to wash the motor with cold water because you will crack the block and the you will be F***ed
johnt2k7 is offline
Quick Reply: clean engines?
