corbeau harnesses?
Old 03-10-2007, 11:53 PM
madden
madden's Avatar
Default corbeau harnesses?
I just bought a set of corbeau forzas and need some harnesses for them.
I need to know what the difference is between the three options 3 Point, 3 point Double Release, 3 Point Retractable ? Which one should I get, how do I install them, and any opinions would be great![/align]
madden is offline
Old 03-11-2007, 04:40 AM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
Default RE: corbeau harnesses?
You don't need new harnesses. I have Corbeau LG1's and they're fine with the stock seatbelt. If you do get one, get the retractable.
Ryan
RyansQuick6 is offline
Old 03-11-2007, 03:46 PM
madden
madden's Avatar
Ya, I know I can use the stock belts, but I want to get the harnesses.
How do I install the harnesses though?
I've seen the harness bars, but they are too pricey for me.
Do the harnesses just bolt to the corbeau seat brackets?
madden is offline
Old 03-11-2007, 06:42 PM
LilRoush
LilRoush's Avatar
Harnesses NEED to be installed with either a harness bar or a cage. It's about getting the proper angle for the shoulder strapes to mount to. I've seen too many people mount the shoulder belts straight down to the floor. That will actually HURT you if you are in an accident. The shoulder belts should go almost straight back at a 90 degree angle (keep them horizontal).
I'd suggest the Sparco harness bar if you don't want to do a cage. It bolts in and still allows the correct mounting points for the belts. For basic street use, I suggest the 2" wide Corbeau 4 pt harnesses. I've used them on several cars, and currently run it on the passanger side of my Roush.
LilRoush is offline
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
rksnow1
09-14-2015 08:46 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: corbeau harnesses?
