Friction Modifier
Old 10-16-2009, 01:53 PM
Fink
Fink's Avatar
Default Friction Modifier
Just double checking if I need to buy friction modifier for when I install my Auburn LSD. I know you need it for installing a T Lok, but unsure for an Auburn. Anyone know?
Fink is offline
Old 10-16-2009, 03:46 PM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
Yup, get the Ford stuff. Friction modifier actually reduces the amount of friction in the diff, otherwise it would be a locker that would wear out almost instantly. It treats the clutches and steels to prevent them from binding too much.
RyansQuick6 is offline
Old 10-16-2009, 04:52 PM
Fink
Fink's Avatar
Ok, thanks. 2.5 quarts of gear lube right?
Fink is offline
Old 10-16-2009, 06:11 PM
Synyster06Gates
Synyster06Gates's Avatar
Are friction modifier and gear lube separate and you mix them together? I'm in the same boat, but with a T-Lok. How much of each, if it is separate.
Synyster06Gates is offline
Old 10-16-2009, 11:20 PM
RyansQuick6
Reverse Gear Member
put the friction modifier in first and then top off with gear lube. I think it's 2.5 quarts if it's a dry housing.
Old 10-17-2009, 08:42 AM
Synyster06Gates
It's 4oz friction modifier, right?
Old 10-17-2009, 08:58 AM
RyansQuick6
Reverse Gear Member
I believe so, it's a little bitty bottle
Old 10-17-2009, 11:43 AM
Shaunmac9128
Shaunmac9128's Avatar
Do you need that in an 8.8 ryan?
edit: #2,000 Woo
Shaunmac9128 is offline
Old 10-17-2009, 12:20 PM
ayrton02
ayrton02's Avatar
edit: #2,000 Woo
The 8.8 t-lok uses the friction modifier as well. So yes, the same would apply with the Auburn.
ayrton02 is offline
Old 10-18-2009, 12:59 PM
RyansQuick6
Reverse Gear Member
Any lsd needs it, regardless of axle size or anything like that.
Quick Reply: Friction Modifier
