V6 to GT rear end swap?
Old Feb 19, 2010 | 10:44 AM
ClemsonSixer's Avatar
ClemsonSixer
Default V6 to GT rear end swap?
How difficult of a process is this? What do I need to fully complete this swap, and do I need to get a re-tune for my SCT? What is the normal price range for a 8.8" out of a salvage yard? Any help is greatly appreciated, thanks guys!
Old Feb 19, 2010 | 11:09 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Welcome to the site.
It's a direct swap if you stay within your cars generation, do a search, this issue has been discussed almost weekly.
Old Feb 19, 2010 | 01:34 PM
Shaunmac9128's Avatar
Shaunmac9128
You can find one for around $300-600 generally. It is a direct swap in. No need for a retune.
Old Feb 19, 2010 | 02:15 PM
Fink's Avatar
Fink
The only time you will have a problem is when you get a 8.8 out of a 94-98, the upper control arm bolt is a 12mm on 94-98 and on a 99-04 8.8 it is a 14mm.
Someone correct me if im wrong but Im pretty sure Im right.
Old Feb 19, 2010 | 04:25 PM
RyansQuick6
Reverse Gear Member
Lower Control arm mount is a 12mm bolt in 94-98, 14mm in 99-04
Old Feb 19, 2010 | 05:59 PM
PNYXPRESS's Avatar
PNYXPRESS
On that note---Is the width the same on 94-98 and 99-04?
Old Feb 19, 2010 | 06:15 PM
neo8222's Avatar
neo8222
it's like 1/2" or 1" short something like that.
Old Feb 19, 2010 | 10:04 PM
RyansQuick6
Reverse Gear Member
the older ones are 1" shorter OVERALL, so 1/2" spacers are needed on each end to compensate.
Old Feb 20, 2010 | 05:42 AM
StangKid018's Avatar
StangKid018
Don't forget the axels are a little shorter on the 94-98 years, thats the problem i ran into with my rear end without staying in the same year, unless your rear end comes with axels if you buy the 94-98 then youll be good, but if they dont then youll need to get shorter axels or your axle seals wont be sealed properly.
So cheaper imo to find the same year range rear end, long story short.
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
PearlGenPu
Aug 12, 2015 01:57 PM
