Dual Exhaust Adapter Kit
Old 03-07-2010, 02:00 PM
rausc
rausc's Avatar
Default Dual Exhaust Adapter Kit
In the following tech article on converting to a V6 exhaust:
http://www.americanmuscle.com/conver...l-exhaust.html
it says that a dual exhaust adapter kit ( http://www.americanmuscle.com/v6duexadkit1.html ) is not a true dual exhaust. But as I understand it the adapter kit attaches to the existing two pipes immediately after the cats and before the Y section. So it seems to me that the two pipes are maintained from the headers/manifolds all the way to the exhaust tailpipes. How is this not a true dual exhaust?
By the way, I am asking because I want a more affordable option than replacing the whole midpipe and catback which looks to be at least $800 dollars which is somewhat out of my budget at this time.
By the way I have a 2000 V6 manual.
rausc is offline
Old 03-07-2010, 02:11 PM
Grumio
Grumio's Avatar
I think that guide is wrong and you are correct. If you get that adapter and the stock cat back from a GT then you should be able to have a very affordable dual exhaust.
Grumio is offline
Old 03-07-2010, 02:19 PM
Shaunmac9128
Shaunmac9128's Avatar
Its not true duals because the adaptor plate has an h pipe built in. That allows you to use any catback made for a GT or the stock GT catback which can be had cheap, with a pair of thrush welded series mufflers for $70 so you'll have a very good sounding exhaust very cheap.
Shaunmac9128 is offline
Old 03-07-2010, 03:14 PM
fordforlife0225
fordforlife0225's Avatar
yea i suppose that wouldnt be a bad setup, idk why more ppl dont have it. i would say though if ur looking for a few more hp wait and get the full set up. that one shouldnt be to bad on sound though. i just spend some money to redu mind. long tubes ($280) + catted h pipe (350) and i aleady have a gt take off cat back with summit mufflers in it.
fordforlife0225 is offline
Old 03-07-2010, 03:31 PM
neo8222
neo8222's Avatar
another on the cheap option is buy 2 mufflers and take it to any reputable exhaust shop and have them cut off after the cat and build the system for you. most shops will do it for 150-300 depending on where you live.
neo8222 is offline
Old 03-07-2010, 03:39 PM
brent4
brent4's Avatar
^^^ do this..
brent4 is offline
Old 03-07-2010, 10:30 PM
rausc
rausc's Avatar
I am somewhat new to this but isn't a true dual exhaust simply having two pipes all the way back and maybe with an X or H configuration? Shouldn't the adapter make the H configuration very similar to a GT set up which is a true dual exhaust? Thanks for the input.
rausc is offline
Old 03-08-2010, 07:19 AM
Shaunmac9128
No, the h or x pipes are crossover pipes. True duals is one exhaust pipe coming straight off each cat (one per side) that never connect.
Old 03-08-2010, 10:31 PM
rausc
rausc's Avatar
I would like to have an X pipe configuration V6 adapter because of the greater performance, but the only adapter I can find is the H configuration( http://www.americanmuscle.com/v6duexadkit1.html ). Does anyone know where to get an X pipe adapter for the 2000 V6?
rausc is offline
Old 03-09-2010, 01:00 AM
neo8222
neo8222's Avatar
a exhaust shop, they can make them
neo8222 is offline
Quick Reply: Dual Exhaust Adapter Kit
