ac compressor leaks at center seam
have a 3.8l, trying to revive ac. Noticed it was low on freon so starting adding freon but not holding a charge. So I got some soapy water in spray bottle and have bubbles coming from center of compressor where it goes together at the seam.
Never had a compressor broken down so is there a giant o-ring at the seam or is it non repairable?
There is a O ring but for the price to recharge the R134, plus purge the system (required when opening the system at all), plus replacing the dryer unit (also has to be done when opening the system according to my Haynes manel) its cheaper to delete the A/C.
Matthew
Matthew
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
95, ac, air, auto, center, compression, compressor, conditioning, gm, leak, leaking, mustang, s197, seam, seams
