01 auto tranny swap to manual
Old 09-01-2010, 07:46 PM
SON1C
SON1C's Avatar
Default 01 auto tranny swap to manual
is it worth it? and how much do you think this would run me total?
SON1C is offline
Old 09-01-2010, 08:50 PM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
the best way to do it is with a donor car, so your cost are basically a new clutch, a donor car, and some time. 94-98 stangs can be had for less than $400 if the engine is blown.
RyansQuick6 is offline
Old 09-02-2010, 08:10 AM
SON1C
SON1C's Avatar
do you think it is worth it, and will it just endup being a huge headache in the end? cuz im so sick of my automatic and i want a manual but I love my car too much to sell and buy and manual.
a 94-98 manual would be fine to swap parts from for an 01?
SON1C is offline
Old 09-09-2010, 07:17 PM
SON1C
SON1C's Avatar
bringing this back, so i've been watching craigslist for awhile, and ive found a t5 tranny from a 94-98 theres a gt t5 and a t5 out of a v6, he wants 350 for the v6 one, and 200 for the gt one but says it needs bearings. I have an 01, would it be fine to swap and what would i need to change..
and can you put 94-98 seats into an 01? ryan you said the seat brackets were different though, what if i got the bracket from that car?
SON1C is offline
Old 09-09-2010, 11:31 PM
sIx
sIx's Avatar
hahaha, I looked at that same CL add just the other day!
And As far as I know, a T5 from a fox body GT will fit as well as the v6, I haven't actually bolted mine up yet but it should be the same.
And the cost of me rebuilding and installing myself the grand build cost is $700~ for everything I've found
sIx is offline
Old 09-10-2010, 05:46 AM
NeoTokyo
NeoTokyo's Avatar
Fox and SN95 GT/Cobra T5's will bolt up but the Fox will have a slightly shorter input shaft which could cause early pilot bearing failure or shaft damage.
Anything Pre-1999 has a mechanical speedo sending unit and needs to be converted to electric, I havnt done this and am not 100% sure how to do it, it may just swap right over.
Everything else that you will need must come from an 01' - 04' such as the ECU.
You may also have an issue with the 01+ trans harness and have to convert other sensors.
As far as rebuilding one, I wouldnt bother. You can find already rebuilt T5's for under $1000 ranging from TKO to beefed up stock GT's. Just keep an open eye and get all paperwork on build info.
Also, you will need the midpipre from a manual 99+
NeoTokyo is offline
Old 09-11-2010, 08:11 AM
SON1C
SON1C's Avatar
why do i need a midpipe from a manual 99+
and i dont need an ecu if i get a manual tune?
are there any sites that sell a package that would have everything that I need?
SON1C is offline
Old 09-11-2010, 09:22 AM
SON1C
SON1C's Avatar
i found a t5 for 350 from a 98... or should i just wait until i can find an 99-04?
SON1C is offline
Old 09-11-2010, 03:05 PM
TheMichiganRA
TheMichiganRA's Avatar
I've been thinking about doing this also. I am curious.
TheMichiganRA is offline
prophotog
09-15-2015 08:38 AM
jaiidutch
09-14-2015 10:29 AM
97SN95GT
09-13-2015 09:45 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: 01 auto tranny swap to manual
