Rearend swap
Rearend swap
Hi i have a 88 cougar v6. Im planning a 5 lug swap, originally i was just gonna take the axles off a 94 sn95 stang but ive been thinking about just swaping the entire rearend. Can someome tell me if its going to be a direct swap with no problems?
Did the Cougar come with a IRS? If not then you will probably be able to do the swap with little to no problems. You can pick up a cheap rear end for less then 100 bucks and try it out. Why do you want to switch out rearends anyway?
Matthew
Matthew
No not for my year cougar. The mn-12 (89-97) cougars came with irs. Im slowly trying to bring my cougar back to life. Im swaping the rears and front suspension so i can have a better selection of rims to choose from for my car. And if possible somewhere down the line possible bigger brakes..... so this should be a pretty simply swap right?
Matt's 95 Stang
10-05-2015 07:16 AM
