HELP, blowing Fuse #1
Old 10-26-2011, 12:13 PM
97greenstang
97greenstang's Avatar
Just to clarify, after disconnecting, I will always be in overdrive?
So I could techincally somehow rewire this if there is a break in line, and/or relocate the o/d switch?
97greenstang is offline
Old 10-26-2011, 01:10 PM
belairbrian
belairbrian's Avatar
Yes.
The control module looks for a momentary signal from the switch to toggle the O/D on off state. When the car is turned off it should revert to O/D on state until the button is pushed. When the green light on the dash is off the O/D is on.
As for relocating the switch this is relatively easy. In fact most after market shifter ***** don't have the whole for the O/D button so you just add amomentary switch to the dash or console.
I've seen them on the drivers side of the shifter surround. Sort of a mirror of the cig lighter. Another option would be to use one of the little change holder openings.
If you wanted to be fancy you could place a convertible top switch in a change holder opening and wire up one side to toggle the O/D. The downside would be the cost of that particular switch.
belairbrian is offline
Old 10-26-2011, 02:07 PM
97greenstang
Thanks, can I keep in contact with you if I have questions?
Old 10-26-2011, 08:53 PM
97greenstang
Update, got it all back together, sure enough, I had pulled the shift head so far up, that it pulled the wires clean out of the connector under the console. Did some testing, taped them up and left wires coming out of bottom of console in case I want to hookup O/D later. There was another connector right under the shifter, just out of curiosity, does anyone know what that goes to? Lastly, after all this, I still dont know if my "cant get out of park" issue is solved, I guess I'll find out in the next couple days.
Old 10-28-2011, 09:57 PM
belairbrian
I'll have the console apart tomorrow I'll look for the other connector and see if I can figure that out.
I had to make a replacement for the plastic piece that goes around the shifter and has the gear selector indicator. Mine was split in two and so were both of the ones in the junk yard.
Old 09-11-2013, 08:56 AM
1992mustang
1992mustang's Avatar
I'm having the same troubles on blowing fuse #1 but mine blows when ever I put it in park. Any ideas?
1992mustang is offline
Old 09-11-2013, 01:13 PM
Daehawk
Daehawk's Avatar
Not read the entire thread. you cant get out of park? Might be a brake switch.
Daehawk is offline
Old 09-12-2013, 11:47 AM
1992mustang
Nooo, I can get out of park fine. Every time I put it in park it'll blow the fuse. I tried a 20 in it and it work for a few weeks then now as soon as I turn the key on it'll pop a 20 & autozone people told me to try a 25 which I did and it'd pop it only when car is put in park.
Old 09-12-2013, 08:37 PM
Daehawk
Daehawk's Avatar
Well you really shouldn't put a larger than called for fuse in something because they are blowing for a reason....though I get miffed and tend to do it on occasion. in my old Corolla I got so tired of it I actually wrapped a blown fuse in tin foil and stuck it back in haha. Thats a fire hazard btw.
I can tell you it's a short or grounding issue but Id be no help in tracing it.
Daehawk is offline
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Sixer4Life
09-29-2015 07:03 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: HELP, blowing Fuse #1
