clutch issues
What's the mileage On the car? It could be a pretty good indication the clutch is on its way out the door. Other than that, I'm pretty sure American Muscle sells firewall cable adjusters for around 40 dollars. You're going to have to get an aftermarket clutch quadrant too if this is the route you're gonna take, those also run about 40 dollars, Maximum Motorsports also makes one thats available on AM
Thanks for your response. 129,000 currently, the clutch was replaced at approximately 120,000. When the clutch is depressed the brakes seem to hold the car from moving when starting out as well. That is without touching the brake pedal
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
