transmission flush or just drain?
Old 02-09-2012, 08:31 AM
Allon Stuchiner
Allon Stuchiner's Avatar
Default transmission flush or just drain?
I am a new owner of 2002 v6 thank y'all for all the great info in here I got 76,000 on my car whats your thoughts on transmission service flush or just drain
can it get can it get damaged from flush?
Thanks
Allon Stuchiner is offline
Old 02-09-2012, 01:35 PM
V6Stang93
V6Stang93's Avatar
Well I just did a clutch job this previous weekend since I had to take the tranny out i thought i wight as well swap out the fluid. I only drained it and filled it up with Royal Purple and it already feels like it shifts smoother. I'm sure a flush would be alot better, but I think a drain would be just fine.
V6Stang93 is offline
Old 02-11-2012, 09:08 AM
Chromeshadow
Chromeshadow's Avatar
Auto or Stick?
Chromeshadow is offline
Old 02-11-2012, 03:02 PM
Allon Stuchiner
It is A/T I don't think transmission service has ever been done on it.
Old 02-11-2012, 07:57 PM
djoneill
djoneill's Avatar
Flushing is for toilets. Drain and fill. If there is a trans cooler line, you can decouple that (top line to the radiator is usually suppl) and pump out the pan before dropping it, cleaning the magnet and changing the filter (if there is one).
djoneill is offline
Old 02-12-2012, 02:18 AM
petrock
petrock's Avatar
+1. To make it less messy when you drop the pan, get a hand pump with a nice long tube and put it down the tranny filler neck tube. Suck out as much oil as you can before dropping the pan. Good luck...
petrock is offline
Old 02-12-2012, 08:02 AM
mustangman02232
mustangman02232's Avatar
I would just drop the pan, do the filter if there is one (i dont remember for the 4R70) and refill with the factory spec'd mercon ATF fluid.
mustangman02232 is offline
Old 02-12-2012, 08:59 AM
MustangSD
MustangSD's Avatar
If it were my car...
If it is shifting normal and fluid is fine I would just do a filter and fresh fluid.
But If fluid smells bad or looks bad - then filter, flush - filter, new fluid -
its more spendy but much less than trans rebuild.
(New fluid, filter, and peace of mind)
MustangSD is offline
Old 02-12-2012, 09:19 AM
mustangman02232
IMO, if it looks or smells bad, your all ready to late to the party and I would just let it be until you need a rebuild,
flushes are great if you do them every 30-50k as recomended when new, but if your over your better off just doing a drain and fill or just leaving it be if your much over 75k
Old 02-12-2012, 10:35 AM
NYstang
MF Staff Snitch
NYstang's Avatar
4R70 does have a filter
NYstang is offline
Quick Reply: transmission flush or just drain?
