Getting all 4 wheels off the ground - safety concern
Hello again!
So my transmission's been acting very odd recently and makes horrid sounds. I think the TO bearing is finally done, possibly some other bearings (pilot, shaft) may be bad as well. I just want to give it a look for now and get the parts that need to be replaced.
I'm currently buying parts to make a home-made step pattern ladder.
The question is - is it safe to get the rear wheels on the ramp, then jack the car up from the k-frame and place jack stands underneath where the frame rails are to level out the car? I'm concerned about the car shifting forward and causing the jacks to tip over and then..
I'm going to put wheel chocks in front of the rear wheels and have the hand brake on and whatnot, but it still kinda scares me.
I just need clearance! Stupid tranny jack adapter on my jack is 11.5 inches high when it's completely low, and I have no idea how tall the transmission would be.
Any ideas or things to watch out for?
Lemme know!
Thank you!
Lemme know!
Thank you!
i would probably try to get the fronts on ramps and the rear on jack stands if possible. i dont have any reason why except its easier to jack up the rear when the front is lifted instead of jacking up the front while the rear is lifted
I was thinking about that, but where would i jack it up from exactly? Is it okay to put the stands under the axles?
I'm gonna go with 03Shadow on this one. Front on ramps, back on stands. Be even better if you could get four jack stands and have them on all four corners. Remember, you may need to go up once you get the tranny down so that you can get it out from under there. Jack stands under the rear axle will be fine. If you are worried about safety, throw some blocks under the tires so that it won't fall.
Appreciate the help guys!
