AODE oil cooler lines
so i broke and fixed my tranny cooler line.... but ive somehow lost the fitting that goes into the transmission. so, theres one on the hose itself before the flare, and then another one goes on top that goes into the transmission? the one i have for the other line will go into the bottom one but wont go into the top (i spent at least 20mins trying to make sure it was going in at the right angle). so the top fitting that goes into the transmission must be slightly smaller than the bottom one, right? would lowes or home depot have these, or is there a place that i can order them from online? knowing both the sizes would help though if anyone can tell me? thanks
ive been building this mustang for about 3 weeks now, and this is one of the last things i need to do. another delay ugggh
if you go to fordparts.com you can look them up in the original Ford drawings. I took a quick look and they show them as the same part and also the same as the ones at the radiator.
but the sight works best if you use your VIN instead of just year and model.
For example the thermostat part number changes during the 98 model year. Using a VIN returns the proper part number
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
