Diagnosing – cranks but won’t start
Rather than hijack this thread, I will make a new one about my blown ECU starting next week. 99 V6, though I believe my experience was equally applicable for 99-04 sixers and V8s. I welcome corrections.
I removed it from the tank. I first disconnected it from the quarter panel but had difficulty getting the filler tube to easily come down with the tank, so I removed it from the tank. . . It may be worth noting that this is the upgraded filler tube (the factory one had rusted out prior).
01 stang Not getting fuel
01 3.8 mustang fuel pressure @ 30 PSI after cycling the Ing. switch 6 or 8 times and listing for the fuel pump and even then it sounded weak and distorted but it did start ??/ Someone said that if I was to pull the vacuum line leading to the fuel regulator ( On the fuel rail ) and found no fuel that the diaphragm was still good ( Still got some doughs as to the printed circuit and or relay on this unit )??/ Also the is what there calling a Fuel Pump Drive Module found in the trunk and it looks like its wired into the inertia switch going to wire loom??/ I'm still not sure this isn't the culprit??/ So I have a Delphi pump on the way ??/ From RockAuto parts catalog ??/ Any body had any encounters with such a problem with these other unit other than the fuel pump ??/ Please advise Steve @ S&J Auto
cranks wont start
I have done all that no start bad pump just paid 150 bucks for have to replace and take back or what?
blkbeltolson
01-13-2014 02:46 PM
Dj96cnvrtblgt
17
02-01-2011 09:43 AM
